Edelbrock aluminum heads >
Old 01-18-2004 | 09:11 AM
Crazyhorse's Avatar
Default Edelbrock aluminum heads
Is anyone running these heads? They look like they're reasonably priced and they come with good valves.
Crazyhorse is offline
Old 01-18-2004 | 10:44 AM
edb07's Avatar
Yes running, yes good valves. Had difficulty getting correct springs for HR Cam. The Marine version of the heads come w/o springs. They do not have a real thick casting. I would not use them on a high hp blower engine.
Ed B
edb07 is offline
Old 01-18-2004 | 11:15 AM
Beak Boater's Avatar
Charter Member # 545
When they showed the new 525 at Miami last year, If I remember right I saw a set of their heads on that motor. Not sure if Mercury uses them on all of them but that ought to tell you something about them.
Beak Boater is offline
Old 01-18-2004 | 08:39 PM
traviss's Avatar
Stop being cheap crazy A few good sets of AFR's and your big blocks will be breathin fire
traviss is offline
Old 01-19-2004 | 05:21 AM
dyno's Avatar
Charter Member #655
he's thinking for me Travis!!and I'm a tight a$$!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 01-19-2004 | 06:39 AM
traviss's Avatar
Originally posted by dyno
I'm a tight a$$!!
Well you said it, i didn't
traviss is offline
Old 01-19-2004 | 07:54 PM
KAAMA's Avatar
Ol' Dandy Dyno Don has a lot a Dutch blood a flowin' through them vains!
Been tryin' to call ya Don!
KAAMA is offline
Old 01-20-2004 | 09:48 AM
Crazyhorse's Avatar
Traviss, my motors breathe fire now.
Old 01-20-2004 | 08:39 PM
traviss's Avatar
Sure.. mr.. I got big blocks with bloooooowers
traviss is offline
Old 01-20-2004 | 08:57 PM
Had their aluminum Performer RPM oval port heads on the 454 in my former boat. With their RPM oval port dual plane intake manifold, 227/235, .594"/.609" 112 degree hydraulic roller cam and mild 34 degree total ignition advance, the engine dyno'd at 464 HP and 510 Torque.
I wasn't looking for the last shred of output - more interested in reliable/no-fuss operation which they gave me.
Escape Velocity is offline
