az-speed v.s. whipple
Old 01-18-2004 | 12:35 PM
boat4life
Default az-speed v.s. whipple
I want to know what everybody thinks about mods. on the 496 HO. Should I go with the az-speed manifold kit or go with the wipple I still want to keep my boat reliable as i can, How many hours can I expect to get out of the moter with the wipple, the az kit is keeping the boat naturally aspirated, but who knows how it will work. Any input is greatly appreciated.
Old 01-18-2004 | 01:22 PM
CAP071's Avatar
I think reliable will go out the window once you start to change it from stock.
CAP071 is offline
Old 01-18-2004 | 02:57 PM
The Whipple will make more power on a 496HO than the AZSM manifold but engine life will probably be cut in half at 5-6 plbs. boost even with the intercooler. The AZSM manifold size and shape will make reconfiguring the 496HO a nightmare! meaning you are going to have to reconfigure all the mountings of the computer, cables, hoses and bottles, etc. for probably 25 HP max unless you change cams and do serious headwork.
If I were you I would wait until March and get our new 496 "BIGPOWER" aluminum heads we are premering at the Miami show. These new heads will take over 100 lbs per engine out of the back of your boat, and make some serious power increases in the 496HO. Couple these with a cam change and a little manifold massaging until our new intake is out in May and you will able to easily take your 496HO to reliable long life 550 HP levels for less money than some of these other systems!
See YA!
Raylar
Raylar is offline
Old 01-18-2004 | 03:43 PM
Default engine mods
raylor what do you have coming out for the 575sci?
Buddy OO is offline
Old 01-18-2004 | 03:45 PM
105mph_38_2003's Avatar
Whipple
105mph_38_2003 is offline
Old 01-18-2004 | 06:27 PM
boat4life
Raylar were do i get some info,web site,or what i'm interseted and i can wait til march or april we don't boat until mid april.
Old 01-18-2004 | 06:31 PM
Raylar, Who are you with? Who is making these heads? and the new manifold?
cobra marty is offline
Old 01-18-2004 | 06:32 PM
boat4life
Engine life cut in half with whipple, whipple says they are the most reliable advanced systems avail.
Old 01-18-2004 | 11:15 PM
Strip Poker 388's Avatar
Rob
Whipple
Strip Poker 388 is offline
Old 01-18-2004 | 11:55 PM
boat4life
How long should the motor last with a whipple if you take care of it and just use wot when needed.
