HP500 Carb serpentine belt conversion >
Old 01-19-2004 | 11:25 AM
p4-33's Avatar
Default HP500 Carb serpentine belt conversion
I'm replacing the factory stamped steel pulleys on my HP500 carb motors. I have individual belts for alt/water/crank, seapump/crank, and PS/crank.
Has anyone ever converted to a serpentine setup? Are the stock accessory brackets in the right locations?
Are there kits available?
Thanks,
Brian
p4-33 is offline
Old 01-19-2004 | 11:58 AM
Official OSO boat whore
No, they won't be in the right locations. You'll need a 100% complete assembly off a existing engine. You'll also need a new power steering pump, water pump, alternator and proably raw water pump. You'll also have to reword the fuel pump too. If you are getting the impression that this is a totally different assembly, then you are correct.
Cord is offline
Old 01-19-2004 | 08:58 PM
p4-33's Avatar
Thanks Cord.
Scrap that idea.
p4-33 is offline
Old 01-20-2004 | 09:36 PM
Fountainclimber's Avatar
http://eddiemarine.com/cart/details....&CategoryID=69
I am not saying it works but ther is a kit.
F
Fountainclimber is offline
Old 01-22-2004 | 04:27 PM
Mrs. Obnoxus
That is just an upgrade to polished pulleys
P4 is talking about switching from V belt to serpentine.
Old 01-22-2004 | 04:56 PM
The one other option would be to go to March Performance. They will sell the pulleys and brackets to convert to serpentine.
Cord is offline
Old 01-22-2004 | 09:01 PM
Madcow's Avatar
I saw it done a couple of years ago by powertorque engines. I thought it wes just pulleys. Mite want to give them a call.
Madcow is offline
Old 01-22-2004 | 10:34 PM
p4-33's Avatar
Thanks for the help, folks.
I've talked to a number of parts houses, CP, Eddie, Doller, Cobra, and I'm hearing the same thing - all new brackets, reloc a different PS pump and raw water pump. Obnoxus is right, the serpentine kits are dress-up kits for existing serpentine motors.
I was hoping this was a simple pulley conversion with the right offsets, sold as a kit. From what I've heard, this is way more than I want to get into. I'll just stick with a set of billet pulleys and go with good quality belts.
Thanks for everyone's suggestions.
Brian
p4-33 is offline
hdtvned
0
11-17-2006 05:44 PM
mr_velocity
3
09-22-2004 10:23 AM
26sonic
2
04-25-2003 07:12 AM
olysan
3
02-22-2003 07:25 AM
BryanTuvell
3
07-24-2002 03:34 PM
