Herring Props?`
Your rpm should be very close between the 30 Hering and the Bravo 1 32. Herring is true-to-pitch while the Bravo 32 is really about a 30.5" pitch. Add the 5th blade and you should be real close.
I agree puder. The Herings are the finest out-of-the-box props I have seen.
I would be wary of purchasing used Herings, however.
Matt
Matt
Wet-Kitty,
That is the $4000.00 question.
We have been working with Hydromotive through the fall and winter on a prop that would compete with the Hering 5 and 6 blade.
I just finished the first set of prototype props. The are a full 15.5" diameter 5 blade propeller with a 31" pitch.
If you like give us a call and I can fill you in on all the details. We also have this prop as a test prop in 31 and 32 pitch.
Matt
877 842 6855
Matt
877 842 6855
This is the prop I was reffering to. I will have some data on it tomorrow after we test it on the Donzi Super V race boat sometime tomorrow.
This is not a P5. It is a Hydromotive prototype prop that is very different than anything else Hydromotive has.
Matt
Matt
Won't know until Miami. Just Got back from Texas. Jimmy bought an Apache.
I heard the Herring 5 bladers will help the midrange acceleration, BUT KNOCKS A FEW mph'S OFF OF THE TOP END.
i WILL LET YOU KNOW.
Fred
Fred
