petoskey michigan area question.. >
Old 01-23-2004 | 07:23 PM
traviss's Avatar
Default petoskey michigan area question..
Our concrete crew is headed up to petoskey for a few days to pour a basement. The boss said were taking all of our snowmobiles.
So how is the snow in the petoskey area?
Are the trails snirt now or still decent?
Are the law enforcement out alot patroling?, do they enforce the excessive noise alot? All of are sleds have loud cans on them
BRAAAAAPPPPPPPPP
Travis
traviss is offline
Old 01-23-2004 | 08:50 PM
traviss's Avatar
Thank you for the info. We should be headed up wensesday morning and staying till friday afternoon. Hopefully we can get some miles on while we are working I need to spend the weekend tuning the suspension and doing maitainance. Even have to align the skis, they have alittle to much toe out opps hit a few things
A question for you guys. Everybody I ask has a different anwser. What suspension setup will give you better traction. Loose or tight limter straps? I have them one hole looser then stock now and the traction was a little better I thought. What would happened if I tightened them up more then stock?
Travis
traviss is offline
Old 01-24-2004 | 05:55 PM
traviss's Avatar
Yup I am all tweaked for now. Strap is one hole looser then stock. I run 216 studs now and the woody's ultra's 10" carbides. It will launch good now, like you said with straps a little looser there is less ski pressure when your on the gas. the way i ride now I get the outer ski hooked in a corner and the inside ski lifts about 6" off the ground and lean yourself in and slam on the gas, right through the corner tight and hooked
traviss is offline
teamsynergy
Sonic
12
08-11-2008 06:47 AM
BK
07-27-2004 09:51 AM
Formula Outlaw
06-10-2004 08:28 PM
Monty
Fountain
2
07-16-2003 08:23 AM
Mr. Demeanor
04-27-2003 05:59 AM
