De-Winterizing:  Fresh Water Tank >
Old 01-28-2004 | 05:05 PM
PhantomChaos's Avatar
Default De-Winterizing: Fresh Water Tank
I've never winterized, but this boat I just got had been winterized because there was pink coming out. How many times to you need to fill and empty the fresh water tank? Someone told me to put a bottle of alchohol in the tank instead of bleach or something......so far, I've only filled it 1 time and just haven't used it but to wash my hands.
PhantomChaos is offline
Old 01-28-2004 | 05:09 PM
LapseofReason's Avatar
I flush mine out once then fill it half way and ad a gal. bleach, drive it some flush that out then fill it and use it. But I never drink it.
LapseofReason is offline
Old 01-28-2004 | 05:15 PM
Rinse it out with bleach and water solution, (or use sodium hypochlorite, same as liquid pool chlorine)
Then fill it with Cuervo.......
jafo is offline
Old 01-28-2004 | 05:19 PM
MitchStellin's Avatar
It is non toxic but tastes like crap. The bleach will help but it is hard to get rid of all the taste. if it will never be winterized again I would replace it. Lets see pics of this boat I keep hearing about.
MitchStellin is offline
Old 01-28-2004 | 05:30 PM
Official OSO boat whore
My suggestion is for you to spray it all over your lawn. It really makes it grow!
Cord is offline
Old 01-28-2004 | 05:40 PM
Wow Nort, I just saw the pictures. It would be hard and expensive to replace that tank. It will come clean some how.
Old 01-28-2004 | 06:33 PM
My friend's suggestion of adding alcohol to it is that it would sanitize the system, but would evaporate fairly quickly afterwards......
Mitch...thanks! Yeah, replacing that tank is not an option.
Old 01-28-2004 | 10:48 PM
1- Fill the take with water
2- Run the water out until no more pink is coming out
3- Put bleach and lime juice together and fill tank with water
4- Turn faucet on and keep filling water tank
5- Do this until you don't smell bleach and lime juice
6- Let the tank run dry and fill it up with fresh water
Buca is offline
Old 01-28-2004 | 11:20 PM
lucy's Avatar
buca knows best!!!
lucy is offline
Old 01-29-2004 | 05:36 AM
and i thought lucy would say... take your boat to florida and avoid the whole practise.
Don
chromecat is offline
