Flywheel
Old 01-29-2004 | 05:48 PM
Default Flywheel
Has anyone tried a flywheel from a SBC on a BBC to save some weight? I'll go internal balance,use a different balancer and get the weight off the ends of the crank.Any ideas.BOB
Bob280Silencer is offline
Old 01-29-2004 | 06:51 PM
mcollinstn's Avatar
Weight savings? Why?
You need a decent flywheel to keep your idle quality.
If you're dead set, then why wouldn't you use an aluminum big block flywheel?
mcollinstn is offline
Old 01-29-2004 | 11:18 PM
A SBC 30 lb flywheel weighs the same as a 30lb BBC flywheel. GM does make a light weight flywheel it's ribbed on the back not a solid casting. I think you want the momentem to stay up on the motor. Besides, all the the SB 400 is internally balanced, where the 454, 502 is ext. balanced.
Mike
goob is offline
Old 01-30-2004 | 05:49 PM
What I meant to say was remove weight from the ends of the crank by going to internal balance.I'm building a 540 and didn't know if the flywheels were the same weight.Thanks for the replys.BOB
1BIGJIM
1
01-17-2007 07:39 PM
thedonz
3
12-03-2006 04:50 PM
29scarab
17
08-24-2006 04:14 PM
Jeff Pierpont
1
10-24-2004 10:33 AM
wetterthebetter
3
01-30-2004 10:31 PM
