Plumbing intercoolers? No pump? >
Old 01-30-2004 | 07:39 AM
Raypanic's Avatar
Default Plumbing intercoolers? No pump?
It has been suggested by a couple engine builders to plumb the intercoolers directly to a transom mount pickup and then out the dump. No pump only a screen in between.
Has anyone done this? Should it be done on a pleasure boat? I would think the lack of water at idle would be a problem when trying to get on plane. Not that I hammer it but at 3500 the boost does just start to build.
I am wondering what speed does this setup start to provide enough water. I know there are many variables but I am looking for some general direction.
This all stems from my whipple setup and the intercooler robbing water from the pipes. I was intending to put a dual or tripple seawater pump but then was told to go without??? I was told not to put in a restrictor in the cooler line. Any Ideas or experiences would be great.
Ray
Raypanic is offline
Old 01-30-2004 | 08:06 AM
totalmp's Avatar
This is correct. Just plumb it directly into a transom pick up. You'd be amazed how much water it will get. Set the pick almost level with the bottom on a conventional, and maybe a little deeper with a step hull. You should check out the adjustable pick ups from CP Performance.
Steve
totalmp is offline
Old 01-30-2004 | 11:20 AM
Reed Jensen's Avatar
My boat had separate pick-ups for the intercoolers when it was equipped with turbos.... I'd suggest that you have a sea strainer and a screen or the intercooler will fill with crap. Mine did... Don't worry about not having enough flow... if you get the adjustable pick-ups ... you will get lots more than needed.
Reed Jensen is offline
Old 01-30-2004 | 12:05 PM
Lee's Avatar
Lee
Or get one of these scroll down to the bottom of the page
Lee is offline
Old 01-30-2004 | 12:11 PM
Fountain38SC's Avatar
I have mine set up that way. No problem. Totalmp has it right.
Fountain38SC is offline
Old 01-30-2004 | 12:49 PM
Breathe Later's Avatar
Ray,
My Whipple setup takes the intercooler water from a T just after the sea pump. The intercooler outlet goes thru the transom to a braided hose connected to an Innovative Marine shower. I'm running a Gaffrig sea strainer plumbed in before the sea pump also. No problems with lack of water to the pipes (CMI's). This setup lowered my 30 psi water pressure to 20-22 psi. Dustin gave it his blessing as well.
Breathe Later is offline
Old 01-30-2004 | 02:10 PM
Havasu Cig's Avatar
My cat was plumbed that way. Pick-up on the bottom, and dumps out the transom over the drive. It actually acted as a drive shower while running. I was running a strainer in between as well.
Havasu Cig is offline
Old 02-01-2004 | 11:51 AM
Infomaniac's Avatar
I plumb them, from a pickup toward the rear of a sponson on tunnels and transom on everything else.
Pickup to sea strainer with relief valve to intercooler to oil cooler to transom dump.
This keeps fuel puddling to a minimum at idle and lets the oil get up to temp.
It starts flowing a soon as the boat is on plane.
Infomaniac is offline
Old 02-01-2004 | 11:58 AM
Mbam's Avatar
Offshoreonly Advertiser
Ray, do not let the cooler core go dry. The transom pickup is OK, but we also run a #4 or #6 line from the sea water pump to the cooler, this pisses just a small amount of water to it at all times. If the core is dry a backfire with flame in the intake can melt the core.
Mbam is offline
Old 02-01-2004 | 01:08 PM
Kanookstr's Avatar
32' SUNSATION
Ray I run mine the same way. except that I use my out drive pickup to supply my inter cooler, and I use a
1 1/4" thru transom for my engine. Dustin Whipple had me do it this way 3 seasons ago, and I have had no problems ever sense
Kanookstr is offline
