square Kicker subs and enclosed speakers
Does anyone have any experiences, good or bad, with the Kicker Solo-Baric (square) subs. I'm thinking about mounting one or two of them under my (Formula 271)rear seat. I'm wondering how much room I need to squeeze the 10's in there. Also, I would like to mount an enclosed speaker, with mids and tweets, under my bolsters so they put some sound towards the back. Any suggestions?
Wiz
Wiz
I do not have any exprience with them in boats but I have 1 10" in a ported box in my F-350 Crew cab and with a Kenwood 650 2ch amp and Boston Acoustic highs it will rattle the windows of the car next to me.Let me know if you have any questions.
Sean
Sean
I have build several systems in boats, and I have always favored the Kicker comp VR's. They handle loads of power and can still play very well in a free-air environment.
Are you planing on building enclosures for the sub/s??
I have two Kicker Comp 10" in sealed boxes in my boat, they slam. Also my friend has 2 of the square ones you are talking about and painted the grills white they look and sound great in his 302 BAJA.
I would say go with two and that way you can feel the music
WILL
WILL
The only place I have for an enclosure would be in the engine compartment and thats not going to work. I didn't know if the storage compartment under the rear bench seat would "act" like an enclosure if I mounted the subs on the outside kinda like Jslack's here....
I have a pair of Kicker Comp VRs in my boat in sealed boxes under the back bench seat. They are ran by a Kenwood 350 Watt 2 Ch. Amp and hit pretty hard. I was going to post a pic but it won't let me. I will try later.
I know bass is mostly feel and not sound, but do they sound good if you throw boxes under the seats? I was considering going with the bazooka tubes under the seats, so they are waterproof but are you guys running the car kickers or the marine version? I have a U -shaped rear seat so i have a bunch of room, but I don't want to cut through the seat base at all. That is why I was leaning toward corner mounting some bazooka tubes. Its simple and clean to install.
I mounted two in an enclosure made to fit under my rear bench in my old Fountain. We angled them down and forward for bounce off the floor, also kept them protected. Made the enclosure from glass covered maple and used it to support the rear bench. We also mounted 6.5's in the outer ends under the bench for mid-range.
