trailers
Old 02-07-2004 | 12:48 PM
2112's Avatar
Question trailers
Need to get a new trailer. Currently have a painted steel Myco which I have not dunked (yet). The new trailer is for a new boat.
If I understand the Myco website correctly, they warrant their steel trailers better than their aluminum trailers when it comes to corrosion.
I do need to dunk this trailer, I love the steel trailers with the reinforcing bridgework but I need to dunk this in Puget Sound (less salty than Atlantic) and do not want a trailer that needs replacement in 5 years.
Your opinions please?
Also, welded vs. bolted aluminum?
2112 is offline
Old 02-07-2004 | 01:07 PM
LapseofReason's Avatar
IMHO it's not the trailer frame that get's fed up the most it's all the axles and brakes and stuff. Most high end trailer makers will put a flush kit on so you can get all the salt out of the hard to reach places.
Yes a alum. trailer wont rust but if you don't take care of either one it's going to need a lot of work in 5 years. I think Myco and Extreme build alum trailers that look close to their steel ones.
LapseofReason is offline
Old 02-07-2004 | 01:17 PM
Reed Jensen's Avatar
You can go with a steel galvanized trailer... that eliminates a lot of the corrosion on the trailer frame and fenders.... but like Lapse says... it isn't the frame that requires all the work... it's the running gear... you'll need bearing buddies and a flush kit that gets the salt off the brakes.... Wash down the trailer everytime it's dunked and you won't have as much trouble. Good luck.
Reed Jensen is offline
Old 02-07-2004 | 01:18 PM
2112's Avatar
Hust be optional on the flush, My current Myco doesn't have one.
what you say makes sense.
2112 is offline
Old 02-07-2004 | 01:24 PM
It's important that you have a flush kit on a trailer with drum brakes... no so much with disc.... the flush kit is just garden equipment installed with a small sprinkler head mounted inside the drum backing plate to flush the salt out. But the salt always manages to f-- up everything... springs... spring perches.... bake lines and wiring... just comes with the territory... It's not bad if you keep up with it... but let it go and you are courting a disaster.
Old 02-09-2004 | 01:03 AM
Hot Duck's Avatar
If you are going with aluminum, I would certainly go with welded instead of bolted together. On Thursday, Bill @ Myco told me that they can paint an aluminum trailer. Maybe he misunderstood me, but I'll swear that he said that they could paint one. That would be the best of both worlds. The looks of a painted steel trailer with the corrosion resistance of aluminum. Now consider that Myco uses stainless brake lines, disc brakes, LED lighting, torsion springs and then add the optional sealed oil bath axles. One of these trailers would be relatively easy to take care of. Just an idea.
Myco Trailers
Hot Duck is offline
Old 02-09-2004 | 01:10 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Why not paint aluminum? Mercury has been painting their outdrives for yrs.
US1 Fountain is offline
Old 02-09-2004 | 01:58 AM
stecz20's Avatar
i have an 89 myco. if you take care of it, it will last you a very long time. mine is in great shape and dont plan on needing another for some time. anything that gets dunked will need maintenance. myco or manning are among your top two in my book. if you take care of your myco you should not have a problem. my .02........
stecz20 is offline
Old 02-09-2004 | 09:23 AM
SS930's Avatar
If I were buying a new trailer steel would not even be considered. You cant go wrong with aluminum, it's much lighter and why buy something that WILL rot??? The only other "must" would be disc brakes and SS lines.
Although painted aluminum would look trick, I think it would be a mistake in the long run.
SS930 is offline
Old 02-09-2004 | 10:06 AM
Havasu Cig's Avatar
We have a 2003 aluminum Myco and I would not go back to steel for a salt water trailer. After I pull it out of the water I wash down the brakes, calipers ect... to keep them from rusting. So far it has been a great trailer.
I have seen some painted Mycos that have been used in salt as well for years, and they seem to be holding up pretty well also.
I would still take aluminum over steel, but if you take care of it the steel should last fairly well.
Havasu Cig is offline
Sea-Dated
Grand Lake/LOTO/E-Dock
10
10-08-2006 12:41 PM
Aboutme3
6
06-04-2006 06:08 AM
FASTERDAMITT
Superboat
76
07-30-2005 07:49 AM
Wild
10
03-30-2005 08:05 PM
Twin screws
Mid Atlantic US
1
02-03-2003 06:38 AM
