what blower on 640 cu.in
Best not to spin a roots blower over 8,000 rpm for any length of time. Whips up more heat than boost.
At 6000 motor rpm, you can overdrive 30%.
An 8-71 at 30%over will give around 14 pounds of boost in a 640. An 8-71 at 15% over will give around 9 pounds. At 1:1 is will be about 4 pounds.
A 10-71 at 1:1 will do about 7 pounds in a 640. At 10% over will do around 10 pounds.
A 14-71 at 1:1 will give you probably 10+ pounds.
These are just guidelines. Each motor, how well its heads flow, carb size, cams, etc will affect the outcome.
I'd say a 10-71 is minimum for that motor, but you could really stretch an 8-71 and make it work.
what the heck are you build'n now
did you get that Hemi car you were looking at?
08 OPA High Points Champion
CigDaze
06-18-2003 08:26 AM
