Velvet Drive Transmission clutches warped >
Old 02-09-2004 | 07:47 PM
force 320
Default Velvet Drive Transmission clutches warped
I had a problem with one of my props turning in neutral. I suspected something was wrong. With the engines off one prop was real hard to turn by hand so out came the motors and this is what I found. Warped clutches, a .070 in cone shaped WOW in them. So what is the max safe HP a 10-017 can handle. Marc at BAM says to go with graphite clutch , is any one using these? Ill probly go that rout any way. Just wanted to share.
Attached Thumbnails Velvet Drive Transmission clutches warped-clutch-disc001.jpg
Old 02-09-2004 | 07:50 PM
force 320
End View
Old 02-09-2004 | 09:28 PM
marinetrans's Avatar
Marc is right. Graphite cluthes have a higher co-efficiency(higher grabbing power). A stock 10-17 is good for 310 HP. But with graphite clutches you can up the hp. Whats nice about graphite clutches is if they let go it doesn't wreck parts like bronze plates do.
marinetrans is offline
Old 02-09-2004 | 10:20 PM
force 320
what will be the hp rating after the graphite clutch upgrade and will I need to increase the pump pressure? I am running 8.1 ho 420 ea
Old 02-10-2004 | 08:06 PM
They sould be alright. Though I would take it easy on wave jumps and holeshots. You will probably puke a drive first before the trans. lets go. I'd keep the same pressure spring and put a plastic windage tray instead of the metal one. I'd put merc's trans. recovery bottle kit on the trans. too.
Old 02-11-2004 | 05:57 AM
Iggy's Avatar
I'm no expert, but how long has that trans been slipping?
Looks like the plates have been over heated which will cause the warping.
Iggy is offline
Brad Zastrow
Swap Shop
0
10-23-2008 09:30 PM
NJgr8ful
13
08-24-2007 09:20 PM
NJgr8ful
08-09-2007 11:02 AM
Excalibur Dude
12
08-31-2006 12:44 PM
RMPRam
15
12-15-2004 04:20 PM
