is 50ft vee too heavy for XR's? >
Old 02-10-2004 | 07:13 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default is 50ft vee too heavy for XR's?
Is a 50ft Vee hull such as a Nor-Tech or Hustler with triple 575's too heavy for XR drives? If the boat is mainly kept at cruising speed and never leaves the water will the drives hold up? I have been told by several people that the drives won't last. Do you think it is true if the proper maint. and the boat is driven responsible?
mcraymond3 is offline
Old 02-10-2004 | 07:46 PM
Von Bongo's Avatar
I remember that someone here posted that their 50 Nor-tech was eating them with 575's. You might search for the thread.
Von Bongo is offline
Old 02-10-2004 | 08:16 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
IT DOESN'T HAVE A CHANCE
WILDTHING TAZ is offline
Old 02-10-2004 | 08:37 PM
Official OSO boat whore
No first hand experience, but I'd agree.
Cord is offline
Old 02-10-2004 | 09:06 PM
mcollinstn's Avatar
They'd be okay if it had nothing more than a stock 496 on it.
I'm saying that 10,000# is the limit for XR's with 500+ hp.
mcollinstn is offline
Old 02-10-2004 | 11:58 PM
Quiet Storm's Avatar
I broke both of mine last year in my 386 Sonic. I'm going to put billet top caps on this year and hope for the best. The top cap broke on the starboard drive taking everything out and the vertical shaft broke on the port side. Had to replace the lower unit.
If your going to use the boat as a floating condo and a cruiser you should be OK but be careful in the rough stuff.
Quiet Storm is offline
Old 02-11-2004 | 01:01 AM
SteveDavid's Avatar
Charter Member #1093
mcraymond3,
I'll probably jinx myself, but I've got triple 700's running thru XR's with about 100 hours since the last drive rebuild. Hull is a 13,000 pound 43' Black Thunder. Never suffered a drive failure per se. I have broken a tooth (twice) in the starboard drive pinion gear. Total hours on the drives are about 450. Center drive is all original. Drive lube is changed about every 50 hours Boat is maintained on a lift as our boating is in salt water. Most outings are long distance involving higher cruise speeds for 2 to 5 hours. Drive ratio is 1.35 using 5 blade Hydromotives.
That said, if I had the room, and the boat was a bit longer there would be triple #6's instead of the XR's.
Steve
SteveDavid is offline
Old 02-11-2004 | 10:41 AM
B-MAX REPAIR
IF YOU DON'T ALREADY OWN THIS BOAT I WOULD LOOK FOR SOMETHING ELSE. I'M SURE THAT THE PRICE LOOKS GREAT IF IT IS FOR SALE. ( STAY AWAY FROM IT )
Old 02-11-2004 | 01:32 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
thanks guys for all the input, keep the info coming! Also, the xr's are new with 1year warranty.
Old 02-11-2004 | 02:30 PM
KAAMA's Avatar
Lightbulb Here's something to think about as well...
If you do happen to choose a boat with the Bravo One XR drives, adding a good drive shower to cool the drives would be a good idea. I have used the Simrek "halo" drive shower with good success. Frequent drive lube changes are wise. This might be a little over kill, but personally, I change mine about every 20-25 hours or so. Also, going easy on the throttles when planing off (no hole shots) and throttling back on the drives during re-entry.
Also, there are some good aftermarket shops out there that add strength and longevity to the existing gear case of the Bravo One XR drive with notable success. I have heard good reports here on OSO about Max Machine Worx upgrades they provide or can install for you. The much larger B-MAX drive is another drive based off the Bravo One drive that could be installed as well.
I wouldn't throw your towel in yet on the Bravo One XR drive just yet. Just remember, there are TONS of Bravo One drives out there and no word on discontinuing them as yet from Merc. The Bravo One is going to be around for a while. Therefore, there are all kinds of up-grades available for the Bravo One from many different aftermarket compainies that are constantly trying to improve and upgrade the Bravo One outdrive.
KAAMA is offline
