Engine Popping >
Engine Popping
Engine Popping
Old 02-12-2004 | 03:06 PM
barron's Avatar
Default Engine Popping
Have a question about popping sound at idle and engine running rough , also back fires through exhaust at times ? Not always! Any suggestions? Need help and a great mech. THANKS!
barron is offline
Old 02-12-2004 | 03:46 PM
jhnrckr
What motor is it? Carb/FI? Where is the boat?
Old 02-12-2004 | 04:58 PM
barron's Avatar
Engine is 502 carb crate motor,merlin heads and intake,crane roller rockers Stainless Marine gen3 Ex. thats all I know about the engines. ST. Pete . Fla. THANKS!
barron is offline
Old 02-12-2004 | 06:43 PM
epeek's Avatar
Sounds like a bad valve or broken valve spring. Don't
know if you have adjustable rockers,but if so,one
may be tight.
epeek is offline
Old 02-12-2004 | 06:54 PM
KNOT-RIGHT's Avatar
Try a compression check on the engine.
I have had a valve hang on the guide and just kissed
the piston. Pulled heads and there it was.
Good luck
KNOT-RIGHT is offline
Old 02-12-2004 | 07:09 PM
blue thunder's Avatar
Do a leak test. I'd guess bent valve too.
Dave
blue thunder is offline
Old 02-12-2004 | 08:06 PM
Vinny P's Avatar
I hate the winter!!
How many hours on the motor? Another possibility is a worn cam lobe. Are you running a roller or flat tappet?
Vinny P is offline
Old 02-13-2004 | 07:41 AM
barron's Avatar
Thanks for all the advise,I still need someone to do the work. Anyone know a great mech? Let me know. Thanks
barron is offline
Old 02-13-2004 | 08:02 AM
P Offshore's Avatar
I know a guy in Clearwater that worked on my 2004 Spectre36 w/900hps; he did not do very much but he also builds custom motors and boats etc... Seems as though he should know quite abit. He is fast and reliable as far as my experience.
Good Luck!
Ray Hanke
Force 10 Marine
727-573-7666
P Offshore is offline
Old 02-13-2004 | 08:11 AM
mcollinstn's Avatar
It's all been covered.
Cam lobe or lifter issue.
Hung, stuck, or bent valve.
Broken valve spring.
best of luck.
mcollinstn is offline
