Blown 25 Baja ?
I seen this boat and I was wondering, shouldn't this run a bit faster?
2001 25 Outlaw. Procharged 496HO. 3.5lbs boost. Runs 75+ on GPS. Labbed 27P mirage+ prop.
Shouldn't this run a bit faster?
I think you are talking about my boat. It run 75 with a full load under normal conditions. It could use some more prop tweeking for more speed. We set it up to be reliable. The best I have seen is 77.8mph GPS. It ran around 67 stock with a 23 Mirage +. For not alot of money you could put on a 5lb kit and a bigger prop probably run 80. 75 is not bad for 3.5lbs boost. Non stepped, Baja. 4 people, cooler and whatever else my wife crammed in the cuddy.
HoustonProp, I thought about going with the Accelerator if I was going to keep it. What is the cost to have this done? It Does pretty well with the 27 but I know it still has some left in it. I wil be calling you when I figure out what I am getting next.
AKA NoMoBoatin
had 01 outlaw 496ho ran 68-70 stock.put 3.5lb procharger kit on after 15 hrs. testing only got upto 78mph on a 26 & 28 pitch prop wasn't satisfied with speed sold procharger to FAST ENOUGH for his 24' checkmate he got 12mph out of it.i had built 572 700+hp and it ran 83mph.a friend of mine has a 1998 25' outlaw with canfield heads on a502 mpi & procarger with 6lbs boost runs 83-86 its for sale right now bought bigger boat.VERY NICE BOAT. email him at adamstk@netzero
