Silent Choice Blockoff >
Old 02-16-2004 | 12:37 PM
Active Streak: 30 Days
Default Silent Choice Blockoff
Anyone ever disconnected their Silent Choice and left the "Y" pipes in? If so, how did you seal off the "Y" pipe where the diverters?
Helmwurst is offline
Old 02-16-2004 | 01:13 PM
Jonas's Avatar
i would like to know that too...
i would actually like to trade my gills with silent choice for a header and pipe set up to eliminate all that stuff..
anyone intereseted?
Jonas is offline
Old 02-16-2004 | 01:42 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Do you really have to seal off the Y-pipe?....
Reckless32 is offline
Old 02-16-2004 | 01:54 PM
jhnrckr
I bought some stainless floor plugs from the Home Depot.
Old 02-16-2004 | 01:55 PM
Jonas's Avatar
HMMMM.... FLOOR PLUGS?? GOOD IDEA!!
Jonas is offline
Old 02-16-2004 | 02:05 PM
rchevelle71's Avatar
Never thought of that, I used 4" PVC.
rchevelle71 is offline
Old 02-16-2004 | 03:37 PM
glassdave's Avatar
Neno the mind boggler
i did almost the same as jhnrckr,except i used the black rubber female block off plugs from the plumbing dept. dont forget to double up the hose clamps. mine have been on for about 100 hours with no problems.
jhnrckr- did you use the ones that have the one nut in the middle that expands the plug or are they hose clamp type also.
08 OPA High Points Champion
glassdave is offline
Old 02-16-2004 | 04:00 PM
MKast
If I'm understanding this, you want to block off the y-pipe. Mercruiser makes a plate that bolts to the inside of the sterndrive. With that blocked off you can remove the y-pipe altogether.
Old 02-16-2004 | 04:05 PM
If you can get to it without pulling the engine????
Old 02-16-2004 | 04:09 PM
Default Block Off
GlassDave: Thought about the rubber caps, but did not know if they would work.
MKAST: You have to pull the engines to remove the Y pipe.
Reckless288: Not unless you want to sink your boat when you are backing up.
