Cam specifications >
Cam specifications
Cam specifications
Old 02-17-2004 | 06:24 PM
Quaid
Default Cam specifications
Does anyone know the cam spec's for the 502 Magnum MPI and the HP500EFI? If not, where can I find this?
Old 02-17-2004 | 07:44 PM
Kanookstr's Avatar
32' SUNSATION
The year would be helpfull
a 1999 502 efi mag Gen 6 roller I had was 224/224 .483/.483
an earlier flat tappet mag cam on a GEN V (pre gen 6 roller) was .512/.512 but 211/227
Kanookstr is offline
Old 02-17-2004 | 07:54 PM
Quaid
I didn't realize they changed the cam for the same motor. The year of the 502 MAG is 1995. I'm guessing the cam didn't change for the HP 500 EFI yet. It is still fairly new.
Thanks,
Dave
Old 02-17-2004 | 09:04 PM
Ric232
Kanookstr, I take it you were able to confirm the Gen 6 profile? My Merc service manual shows the cam specs for my Gen 6 as the spec you show for the Gen 5. I would not surprise me if the book was wrong. I guess it makes sense that they could reduce the lift when going to the roller cam since the lobe ramps are steeper.
Old 02-17-2004 | 09:09 PM
Ric232
The 500EFI cam is Crane part # 169621
Lift .598"/.610"; duration 230/236 LSA 114
Old 02-17-2004 | 11:07 PM
I think your the cams were the same in the 454mag and 502mag for that vintage.
Is your 502 mag the 390hp carbed version???
It should be a flat tappet with 220/220 and .510/.510. on a 115.5 LSA.
Griff is offline
Old 02-18-2004 | 08:21 AM
Ric232
Quaid, aren't you glad you can come to one place to get the single decisive answer ???
Old 02-18-2004 | 02:26 PM
Really need the Merc engine serial # or some more info to determine exactly what engine he has.
Changes to roller cams happened in 1995-1996.
If its a roller than Kanookster's is the one.
Griff is offline
Old 02-18-2004 | 02:38 PM
Quaid
The number stamped in the block is "N2507" (seems kinda short to be the serial number). My boat is a 1995, but I bought the motor in 2001. It was fresh out of the crate. I was told it was definitely a roller motor.
Old 02-18-2004 | 02:39 PM
Quaid
By the way, it is a EFI 415HP
