How to Crate a Motor for Shipping >
Old 02-19-2004 | 12:12 AM
Kokopelli's Avatar
Question How to Crate a Motor for Shipping
Just sold my take out 502 and need to crate it up for shipping. Local dealer want's $250 for an old used merc. crate - A-hole. What's the best way to securely crate it and secure it to a pallet so we can load with a forklift?
Kokopelli is offline
Old 02-19-2004 | 12:46 AM
Reed Jensen's Avatar
Who is your local dealer that wants $250.00 for a $50.00 dollar job?
Reed Jensen is offline
Old 02-19-2004 | 07:11 AM
Audiofn's Avatar
Charter Member #232
Mercury has a 150 (I think it was) core charge on those crates that he will loose if he gives you one. Then another hour to load it in... I know it seems outrageous but his hands are kind of tied.
Get a good pallet, put a piece of 3/4" Plywood on top of it. Screw that into the pallet, then I guess we do not know if you are leaving the motor mounts on or not????
Jon
Put your best foot forward!
Audiofn is offline
Old 02-19-2004 | 07:13 AM
Audiofn's Avatar
Charter Member #232
If you are then just get some large blocks of wood and put them down under the mounts and another at the back of the motor and screw it all together and run a threaded rod through the motor mount and down through the plywood and bolt it all together.
If you are taking off the motor mount stuff then you will need to figure out a way to sapport it from the sides of the engine some how......
Audiofn is offline
Old 02-19-2004 | 07:21 AM
Kokopelli's Avatar
I'm leaving the mounts on. Isn't there some type of cheap cradle I can buy to bolt the motor to and then bolt it to the pallet? It seems to me I've seen these but don't recall where or when.
Old 02-19-2004 | 07:42 AM
Audiofn's Avatar
Charter Member #232
Not sure but since you are leaving the mounts on it is really easy to just get some 6X6 blocks (you can measure to make sure that is large enough to keep the oil pan up off the pallet) and the threaded rod. It is acutally really easy. If you can grab a little bit of that plastic wrap from U-haul and wrap it up good to protect the motor. Should be fairly easy once you get started with it
Jon
Audiofn is offline
Old 02-19-2004 | 11:36 AM
GregP's Avatar
Get a cheap engine storage cradle from Jegs or Summit, lthey bolt to the block mount pads and to the bellhousing bolts. Leave the wheels off the cradle and bolt it to the pallet. Then put a couple of the plastic engine storage bags over it (from same stores). Build a wood frame from 2x2's then attach some 1/4 ply to the frame to protect it (and seal it from curious eyes).
-Greg
GregP is offline
Old 02-20-2004 | 04:24 PM
22Pachanga's Avatar
Get a pallet and do the plywood on top. buy an big block cradle for $30 and bolt the engine to it and bolt it to the pallet.
22Pachanga is offline
Old 02-21-2004 | 08:24 AM
Kokopelli's Avatar
Thanks guys. The storage cradle bolted to a plywood covered pallet seems the most secure way to go although it does leave you with the problem of removing and then having to attach to the pallet the motor mounts, flywheel, coupler and bell housing. Not an issue for me any longer though, the guy who bought my motor is going to haul his boat down and have my mechanic install for him.
Lofty
03-20-2007 08:35 AM
CHAOS REIGNS
7
10-17-2004 07:26 AM
Madcow
09-30-2004 06:50 PM
cobra marty
5
10-16-2002 05:09 PM
Pocket Change
04-10-2002 01:39 PM
