Removing bottom paint
Old 02-19-2004 | 09:15 AM
GregP's Avatar
Default Removing bottom paint
Does anyone have a guess at the cost to have the bottom paint removed from a 34' V and the hull bottom re-polished? (and no, I don't want to do it myself, I just don't have the time to take on such a task, and would rather spend my available time doing something much more pleasant)
Thanks - Greg
GregP is offline
Old 02-19-2004 | 09:17 AM
tomtbone1993's Avatar
10,000,000,000.00 PESOS
tomtbone1993 is offline
Old 02-19-2004 | 09:18 AM
mr_velocity's Avatar
Yea here in NJ you can go to any train station and get people for $5 an hr and a Big Mac for lunch. They work really hard too just don't let then use power tools that cut.
mr_velocity is offline
Old 02-19-2004 | 09:20 AM
GregP's Avatar
I little better guess than that, please
GregP is offline
Old 02-19-2004 | 09:40 AM
MitchStellin's Avatar
I would like to know also as I may be doing the same. My guess is lots of sanding and then painting. Lets hear it!! Whats it going to take.
MitchStellin is offline
Old 02-19-2004 | 09:47 AM
try west marine stores. they have a product to remove bottom paint. it's called peel away bottom paint stripper. looking at the catalog it says to apply and let it work for 2-24 hrs.no fumes , 1 gallon costs 60 $ and treats 50 square ft. on page 338 of the 04 catolog.
open87 is offline
SS930's Avatar
You guys should ask Glassdave... I'm sure he can give some input.
SS930 is offline
Old 02-19-2004 | 10:39 AM
cuda's Avatar
I took my 242 Formula to a bead blasting shop. They did it for right around $300, however, I recomend that you DON'T do that. It damn near ruined my hull, in some spots it looked like it was shot with number 8 bird shot. I did one myself with a pressure washer and a sandblasting attchement. It came out much smoother than the bead blasting.
Bead blast.
You can see some holes where it shot too big a chunck out or something.
cuda is offline
Old 02-19-2004 | 10:41 AM
cuda's Avatar
Here's part that I sandblasted myself. I imagine you could just hire a pressure washing guy to do it for you. It took 550 pounds of fine sand to do a 20 foot boat. It came out much nicer than the bead blast.
cuda is offline
muffman's Avatar
I did mine myself and it took about 30 hours of work.
muffman is offline
