Bravo One Won't Trim  Up >
Old 02-20-2004 | 11:10 AM
Mark_McCuen
Default Bravo One Won't Trim Up
I saw this post before but my situation is a tad different: Trims down ok. Trims up intermittently say maybe 20 to 1. Solenoid always clicks. Same results with Up or Trailer Buttons. My question: Should I be looking at the solenoid since it Does click or to the pump motor?
Old 02-20-2004 | 11:31 AM
marinetrans's Avatar
If it trims down no problem its probably a trim solenoid or up circuit winding in the field and frame. Try jumping the heavy blue wire and the heavy red together. If it trims up its probably the solenoid. Use a heavy jumper wire.
marinetrans is offline
Old 02-20-2004 | 01:39 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
HOT WIRER EACH DIRECTION ,THAT WILL TELL YOU WHAT'S GOING ON
WILDTHING TAZ is offline
Old 02-20-2004 | 02:14 PM
outlawinil's Avatar
Be sure your batteries aren't drained down too low. Could be if sitting in storage.
outlawinil is offline
txriverrat2001
1
02-09-2007 06:36 PM
24degrees
2
09-07-2006 01:07 AM
Vmax
8
07-05-2006 10:01 PM
CNC
2
06-10-2006 07:36 AM
Erie Desire
5
07-16-2003 09:02 AM
