5 in. lbs.  dial torque wrenches >
Old 02-20-2004 | 09:10 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default 5 in. lbs. dial torque wrenches
Need to measure down to 5 in. lbs for bearing preload for assembling my lower drive unit.
Do aircraft mechanics uses these? Having trouble locating one.
US1 Fountain is offline
Old 02-21-2004 | 07:39 AM
WILDTHING TAZ's Avatar
B-MAX REPAIR
I GOT MINE FROM MAC TOOLS. I PAID 125.00 FOR IT. IT STARTS AT 10 INCH POUNDS BUT YOU CAN USE IT. IT IS ONLY A 1/4 INCH DRIVE YOU HAVE TO USE SOCKET ADAPTERS TO GO TO THE 1 5/16 SOCKET TO TURN THE PROP SHAFT WITH 2 REGULAR NUTS JAMMED TOGETHER ON THE PROP SHAFT. IF YOU SET IT AT AT 10 INCH POUNDS THE BEARINGS WILL WEAR IN AND LOOSEN UP A BIT ANY WAY.
WILDTHING TAZ is offline
Old 02-21-2004 | 08:00 AM
Craftsman has a nice digital torque wrench 1/2" drive which measures down to 0.1 lb-ft. How is that compare to inch pounds? www.craftsman.com search torque wrench.
cobra marty is offline
Old 02-21-2004 | 08:12 AM
formula31's Avatar
McMaster Carr has them, thats where I bought mine
formula31 is offline
Old 02-21-2004 | 08:17 AM
MACDAD260's Avatar
Charter Member #818
I am a Mac Tools Distributor. Here is some info on our Dial Torque Wrenches that might be of help. E-mail me at [email protected] if you would like some more info.
Doug
Attached Thumbnails 5 in. lbs.  dial torque wrenches-dial-torque-wrenches.jpg
MACDAD260 is offline
Old 02-21-2004 | 11:05 PM
Zanie's Avatar
Go to:
http://www.torqwrench.com/
This company has been manufacturing torque wrenches for a certain rather pricey tool company (starts with an "S") since 1938.
Look at the site, you'll recognize the brand.
DS
Zanie is offline
Old 02-22-2004 | 04:18 PM
Ginger or Mary Ann?
So a new Mac wrench was only $125? I would have expected more since the Snap-On is going for alot more than that.
Really don't want to buy for what will get used for a couple of minutes and then never again. Going to check with some mechanics at the airport I work at. Figure that if anyone uses them, they would.
miamioffshore
16
03-24-2006 09:49 PM
iamfaster
7
05-17-2005 11:16 PM
New boater man
11-11-2002 11:01 AM
New boater man
4
10-30-2002 06:50 PM
