do i need more setback >
Old 02-22-2004 | 03:17 PM
big poppa pump's Avatar
i have 24 skater with 260s 6 inck setback, it seems i trim a whole lot to acquire 110 mph , props are spun inwards, it seems every tap of the trim button you can feel the boat just take off
big poppa pump is offline
Old 02-23-2004 | 10:02 PM
Ryan Beckley's Avatar
Racer
Racer
The props turning in creates alot of stern lift. It is also alittle hairy running a cat that way. I wouldn't go with more set back. I would think you should be between 1.5-2 inches above the bottom. I would think your boat is nearing its top speed around 110.
Ryan Beckley is offline
Old 02-24-2004 | 08:00 PM
with the 28 skaters going faster and the 22 talon going around 130, i would think this has 120 possiblities? what do you think
Old 02-25-2004 | 10:22 PM
apache21's Avatar
110 is pretty dam Fast. Is there a reason you need to go 120+ in a 24 Skater. I worry you could get hurt. Be sure to wear a helment and lifeline.
apache21 is offline
Old 02-26-2004 | 07:57 PM
Racer
Racer
I do not think a 24' will go 120 and NO it doesn't need to. The 28 is a much freinlier boat and safer. As for the 22 Talon those speeds are with GIANT blower motors or hopped up grenade outboards. 110 in a 24' is PLENTY FAST.
Old 03-01-2004 | 06:11 PM
apache21's Avatar
110 is flat hauling
apache21 is offline
Old 03-05-2004 | 01:43 PM
Skaterfast
Yes you need more set back.I put on 6 inches last summer and picked up 2mph.If I had the money to buy 16" with new cables,etc I would do it.I also need excesive trim to make her fly.Your not alone.Right now I'm looking for one peice exhaust plates so I can run transome mounted water pickups.I'll be intaling those next month so I can raise my motors.I know for a fact this will give me more than 3mph.
4mulafastech
0
05-14-2007 01:05 PM
X-Rated30
06-10-2005 03:15 PM
big poppa pump
Skater
3
11-23-2002 11:37 PM
Skaterfast
Skater
3
05-13-2002 03:11 PM
Skaterfast
1
05-05-2002 12:07 PM
