Consuming oil
Can I lose oil through the oil cooler on a 454 mag efi? If so, would I notice my oil mixing with water? So far, I'm just using oil with no signs of water in my oil. I will use 1 quart of oil in 2 hrs of running at 3500 rpms. It seems that the starboard side exhaust leaves more residue on the transom and the inside of the exhaust tip. The motor runs strong other than the oil consumption. I changed the rings and bearings and had the cylinders honed about 40 hrs ago. I had oil consumption before the rebuild, but it didn't seem as bad as it is now. I believe I have being using this much oil since the rebuild? Any help would be appreciated. Thanks.
Yes you can leak oil out of an engine oil cooler into the water system. Remember the oil system running has far more pressure 50-60lbs than the water system and you will never see the loss. I should pressure check your oil cooler to make sure its ok. Sometimes guys forget to change the zinc plugs in the cooler and the cooler passages can corrode thru. Just a thought.
Raylar
Raylar
JGB
21
02-08-2011 11:24 AM
jeff32
06-28-2006 08:48 AM
FlyFast
13
05-10-2004 11:39 PM
