HELP!! BAD VIBRATION when turning or trimming
Hi,
I have a Volvo DP-SM outdrive. When driving straight she's very quiet. However when she's trimmed up/down or I turn left or right, there is a terrible vibration. It's not a grinding sound or knocking, but a vibration.
I was reading that it could be from several things.
1. Misalignment of the drive
2. U-joints
3. Gimbal bearing
Anyone out there experience a similar problem. Any Advice?
Thanks,
Miles :-)
2. U-joints
3. Gimbal bearing
Thanks,
Miles :-)
I agree with blue thunder. Better get it fixed now!! If a u-joint lets go, it will destroy the transom assembly. You would no longer be able to put on a bellows as it breaks the rim it attaches too. Now say- "abandon ship" as it takes on water!!
Well, I pulled the drive off. It's a 2001 DP-SM. Turns out there was a small amount of water in the drive bellows. The gimble bearing came out stuck to the input shaft. I have a feeling the vibration is from the gimble bearing since it looks so bad and the inner and outer races can wigle.
Now, the u-jouints, although dirty are real tight. After cleaning them up, they don't appear to be worn.
Is there a way to determine if the u-joints are going bad? Loose, gigly, etc?
Thanks for the help.
Miles :-)
Miles :-)
Went through this on a Four Winns w/ Alpha drive. The gimble bearing went south. Had water in the bellows. Replaced it, too. If you are mechanically inclined at all, you can do the labor yourself. I replaced the u-joints, as I heard horror stories of them coming apart, parinoia took over...
Insurance like this is cheap
Go to a drive shaft parts house.... Merc u-joints are just Dodge truck u-joints & cost only $7.00 each... might as well replace them as take a chance. It's worth $14.00 to not have to pull the drive off again.
