Removing cockpit carpet glue? >
Old 02-27-2004 | 11:25 AM
Love Machine's Avatar
Default Removing cockpit carpet glue?
I'm about to order new cockpit carpet. Thanks to all the threads I researched. If Sonic's price is to high then I'll be going with R&R Textiles.
However, my old carpet (which stinks to high heaven ) is glued. When I take it up I want to remove the glue and I have no idea what to use.
Anybody have ideas? The new carpet is a lay-in and I don't want dirt collecting in the old glue.
Love Machine is offline
Old 02-27-2004 | 11:54 AM
cuda's Avatar
No easy way that I have found. I use a four inch hand scraper and scrape it off. After you get it thin enough, mineral spirits or laquer thinner may take it off. I've never tried to get it that clean because I'm usually going back over it.
cuda is offline
Old 02-27-2004 | 12:02 PM
Official OSO boat whore
I'd try laquer thinner (slow) and a putty knife. Oh, and be sure to wear some thick rubber gloves and a mask.
Cord is offline
Old 02-27-2004 | 01:00 PM
formula31's Avatar
Maybe some of that Goof-Off stuff will work, never tried it on carpet glue either though.
formula31 is offline
Old 02-27-2004 | 01:05 PM
3M makes an adhesive remover. Try it, it works on almost everything. You can buy it at good automotive stores (that have painting supplies) and some marine supply stores.
Gary
Gary Anderson is offline
Old 02-27-2004 | 01:45 PM
formula31's Avatar
Yea, that adhesive remover is great. Even works on silicone to a point. Try lighter fluid. I swear it is exactly the same thing and costs 1/10. Dont smoke LOL.
Old 02-27-2004 | 10:28 PM
Notched_Baja
M E K stands for Methol Ethol Keyton. I dont know if the spelling is correct put we use it at work all the time to remove adhesives. This is an industrial chemical and can be found easily.
Old 02-27-2004 | 11:41 PM
Tinkerer's Avatar
NO ONE mentioned anything about fumes.
most of those chemicals are deadly in an enclosed area.
make sure that you have a fan blowing fresh air into the area where you are working.
Some of those chemicals may be heavier than air and a mask wont help if the only thing to breath is the chemical
Tinkerer is offline
Old 02-27-2004 | 11:55 PM
Goof Off will work. Spray it on or pour it on, you can get it it different forms of applications. Lowes, Walmart, etc. carries it.
Good luck
Active Mike is offline
Old 02-28-2004 | 09:48 AM
mcollinstn's Avatar
Try the milder stuff first.
If that won't do it, go to acetone.
Acetone won't kill the gelcoat.
MEK will dissolve gel, won't it???
mcollinstn is offline
