head stud sealer. >
head stud sealer.
head stud sealer.
Old 03-06-2004 | 05:51 PM
traviss's Avatar
Default head stud sealer.
I used normal GM sealer last year and it really wasn't made for what i was doing.
So what should be used for a sealer on my head studs going into the block?
Travis
traviss is offline
Old 03-06-2004 | 06:08 PM
blue thunder's Avatar
I've been using #2 permatex or aviation sealer for years an never had a problem.
BT
blue thunder is offline
Old 03-06-2004 | 08:53 PM
traviss's Avatar
thanks guys
traviss is offline
Old 03-07-2004 | 10:10 AM
10x's Avatar
10x
10x
Aviation sealer !!! dip the headbolt, then brush off the extra.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 03-07-2004 | 07:58 PM
Crazyhorse's Avatar
ARP markets a stud sealer for their studs but I've never used it.
Crazyhorse is offline
Old 03-07-2004 | 08:42 PM
Merc and OMC make a gasket/ thread sealer, similar to aviation sealer. I use it on all the engine bolts as well as outdrive bolts. It works great, and you'll always get the bolts back out. Works great on trailer wheel studs too!
Paul
Liberator21 is offline
Old 03-08-2004 | 06:04 AM
dyno's Avatar
Charter Member #655
Will the aviation sealer work on head bolts too???or will it effect your ability to tork them accurately?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 03-08-2004 | 07:45 AM
jaroot's Avatar
Hylomar is the WAY TO GO... Period... i've used it on studs and head bolts that pass into water and i've never had a leak and you can remove the stud or bolt easily at a later date.
I've been using this stuff for years and then one day i was thumbing through Precision Engine Magazine and came across an article on sealants... Hylomar was actually their recommendation for that application... for anyone who doesn't know.. Precision Engine mag is a very technical engineering R&D type of publication... it's well worth reading if you are into that kinda thing.. some of the articles hurt my head too...
JR- toot toot
jaroot is offline
Old 03-08-2004 | 07:53 AM
jaroot's Avatar
Also, after performing a few different fastener torque studies for some of my fixtures and what not, with various lubricants i've come to be a religious user of ARP Thread lubricant on all torqued threads unless they must be sealed (head bolts in water)... you get extremely repeatable torque values on a fastener, it takes less torque to achieve the proper amount of fastener stretch due to friction reduction and you gain increased eveness across a group of fasteners... such as head studs, rod and main bolts and studs, etc.
jaroot is offline
Old 03-15-2004 | 09:37 PM
boatinbill's Avatar
Registered User
Ok, so Aviation sealer is the right stuff, where can I get it?
boatinbill is offline
