Bravo Gear Drive Ratio >
Old 03-06-2004 | 07:36 PM
Notched_Baja
Default Bravo Gear Drive Ratio
I have 1.36 gear ratio in Bravo 1 drives. Can someone explain to me if you change just the uppers or lowers or both to get to a 1.50 ratio.
Old 03-06-2004 | 08:52 PM
mcollinstn's Avatar
uppers
mcollinstn is offline
Old 03-07-2004 | 08:24 AM
Mbam's Avatar
Offshoreonly Advertiser
What mcollinstn said unless they are XR's, then it is the lowers.
Mbam is offline
Old 03-07-2004 | 08:32 AM
Notched_Baja
Thanks for the replies.
Does this mean that all bravo's use the same lower drive gears?
Old 03-07-2004 | 10:35 AM
P Offshore's Avatar
Not in an XR, I think that is correct in a standard Bravo 1
P Offshore is offline
Old 04-09-2004 | 08:29 AM
powerguy's Avatar
Notched_Baja - Do you still have the 23 hydromotive 4 blade props and are they available?
Thanks,
Dave
powerguy is offline
Old 04-09-2004 | 09:12 AM
merlin540
xr's change ratio in lower xz,x,std bravos change ratio in uppers if you need gears pm me i have some new and used take outs available
AXION
Sonic
5
06-16-2021 07:07 PM
MacGyver
Prop Talk
1
11-03-2006 06:38 PM
Jassman
07-04-2004 10:41 AM
Interceptor
4
03-20-2003 06:49 AM
