Hows this 502 look for a marine application??
Originally posted by open72
have to change cam, head gaskets, valves, oil pan, etc... all you can really use is the block , rods, pistions.
Originally posted by KaamaScarab30
Ummm, why? I can see changing gaskets and oilpan, why cam and valves?
Don't need inconel valves unless its blown.
Needs brass freeze plugs.
Needs J-tubes and flame arrestor and swap the supplied starter for a marine starter.
Many guys are running the ZZ502 cam with aftermarket manifolds and extended tailpipes with no troubles with reversion.
If freshwater, it will make a good setup.
If salt, then you gotta get a marine intake and hardcoat the heads or put closed cooling on it.
Originally posted by Back4More
Blocks run colder and pistons run hotter....and with a blower on top even hotter.
More clearance between piston and cylinder...ring ends get more clearance too
Blower pistons are a must with that much power expected out of it...and a high quality set of rings too.
More clearance in the rod bearings for oil flow to remove heat from the bearings.
Re balancing the rotating assy...If its anything like the ZZ502 it will rattle it's self to death in no time.
If your looking for a 1000hp blower motor you better plunk down the cash for top of the line internals...not to mention a beefy aftermarket block...There is no such thing as a cheap marine blower motor making 700+hp.
I not slamming this bad assed crate motor, but it is not for powerboats...I read alot about people blowing up the 502s running them at the track.
I know nothing about detailed marine engine building but learned a bit while having mine built.
Oh, and we did'nt even talk cams and valve train yet....
