Merc's new Bravo drive
Starting w/ serial #ow100000, the upper of the Bravo will now take shimming tools and gear lash flags to set up.They have shims and a new bearing cup in the bearing pack.Then you use a shim tool to check the pinion depth. Next they have a gear lash flag to check back-lash. 7 new tools will be needed and 4 new flags. Maybe they will last a little longer w/ this new set-up process.
when it's time to freshen my 03 xr drive can these newer methods be used or does it require a new housing/internals (aside from shims etc) makes sense to me- I've done lots of ring and pinion jobs.
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
panteraracin
3
02-07-2002 10:36 PM
