fiberglass gas tanks?
Old 03-09-2004 | 08:58 AM
Official OSO boat whore
Default fiberglass gas tanks?
I posted a thread on this some time ago and didn't get many responses. At that time, I was wondering why people bothered with aluminum gas tanks when they could just build one into the boat out of fiberglass. Some members knew it had been done, but I didn't get much more info than that. Well, during out tour of Skater, I saw that they were not using a aluminum gas tank. They would line a section of the tunnel with this white stuff. Drop in some dividers to reduce the fuel slosh, and then some how cap it. I don't know what the liner was, what the divider was or how they sealed the tank and put the fittings in. Can anybody help me with this?
Cord is offline
Old 03-09-2004 | 09:02 AM
All I know is that fiberglass tanks that are untreated eventually start deteriorating and end up in your fuel filters and carbs. It get's real bad. Perhaps the white stuff Scater uses can prevent this from happenning. I would also guess that using a tank would be slightly safer during a crash and delamination.
jody165 is offline
Old 03-09-2004 | 10:00 AM
Madcow's Avatar
Sonic is doing R&D on this idea right now.
Madcow is offline
Old 03-09-2004 | 10:49 AM
wwwTOPDJcom's Avatar
I like to see a fuel cell style I actually was in the water
after a fuel spill trying to salvage a boat, if you have ever gotten fuel on your skin and "Im not talking your Palms" you will know what Im talking about. it burns like hell. Being in a accident and gettng gas on you is NO fun aside from being very dangerous
wwwTOPDJcom is offline
Old 03-09-2004 | 10:50 AM
There must be a way to make it work. I know that most new gas station underground storage tanks are fiberglass.
Cord is offline
Old 03-09-2004 | 10:55 AM
Flashwave's Avatar
My motorcycle gas tank was "cream coated" to prevent rust from getting into the gas. Could be the same stuff.
More info on tank sealers.
Flashwave is offline
Old 03-09-2004 | 11:04 AM
What about coastguard certification?
When I was looking at Motion they told me that they built it into the boat and said they needed the added strength built in for the boat. They also wanted to know if I was using 2.5's...... If so they would have to use a different resin because of the oil mix in the fuel would break down the resin.
macvtt is offline
Old 03-09-2004 | 11:16 AM
mirageman
Can you say, "Exxon Valdez"?
Old 03-09-2004 | 12:23 PM
glassdave's Avatar
Neno the mind boggler
we have a place in town here that renews old rusty automotive fuel tanks. they use some kind of off white coating in the process that l'm sure is the same stuff. i have had several tanks done and they are guarnteed for life. check your phone book you might have a place near you that can give you the name of the stuff. also look under radiator repair as many of them do the fuel tank stuff too.
08 OPA High Points Champion
glassdave is offline
Old 03-09-2004 | 12:32 PM
glass-if you had a tank to that point of completion, how would you go about putting the lid on it?
Cord is offline
