Gil exhaust question >
Old 03-09-2004 | 03:40 PM
racer340
Default Gil exhaust question
Anyone out there have a set of Gil manifolds handy that could measure center to center across the studs connecting the manifold to the tailpipe/riser.Ive got manifolds from Drake and they are identical to the gil 3 piece manifolds but cant get the measurements anywhere to know if the brackets/tailpiece and gaskets will work on mine.BTW anyone ever hear of Drake?
One other question,besides using the y adapter for the thermostat hoses,will I need to move the power steering pump,its a 454 magnum engine.Water inlet is same as on gil ,4 inlets going into a forward facing rail.Would like to have everything I need to get this done before I start.Thanks in advance
Old 03-09-2004 | 08:25 PM
homan
does the pic. help. I don't think I had a y adapter on my old set it came off the therm. housing I think not sure though
Old 03-09-2004 | 09:09 PM
homan
Just found this I don't know if it helps I have a crossover. I think I put spacers to raise the filter up so I could go under it.
gripit
2
01-08-2007 07:25 PM
gripit
17
12-30-2006 11:38 AM
Gary864
06-07-2006 06:39 PM
Dangerous Dave
5
08-02-2004 10:25 AM
