Fuel / HP curve for 454 mag >
Old 03-09-2004 | 05:42 PM
Stormrider's Avatar
JC Performance Engines
Default Fuel / HP curve for 454 mag
Does anyone have the graph for HP/ fuel usage
for a 1988-89 454 mag 365hp?
Stormrider is offline
Old 03-10-2004 | 11:26 AM
Stormrider's Avatar
No one has this?
Or does anyone know the fuel burn rate at certain RPMs?
rob
Old 03-10-2004 | 11:38 AM
mikev's Avatar
fuel burn rate would vary depending on the boat it was in. a heavier boat will require more throttle to maintain the same rpms vs. a lighter boat. same reason you get worse gas mileage towing your boat vs. driving your truck unloaded.
mikev is offline
Old 03-10-2004 | 12:09 PM
Stormrider's Avatar
Are you sure that's right?
If an engine is turning 3000rpm it needs so much fuel to turn. Why would it need more fuel to turn the same RPM.
I understand you need more rpm to run a greater speed in a heavier boat.
But shouldn't rpm be rpm under any load?
Isn't the fuel metered to a specific amount per cylinder per crank turn?
Old 03-10-2004 | 12:13 PM
mikev's Avatar
nope your truck runs the same rpm at 70 with a load or not but you get different mileage pulling a load vs. running empty
mikev is offline
Old 03-10-2004 | 12:15 PM
Payton's Avatar
Charter Member #927
an engne under load will burn a lot more fuel than an engine running under a light load at the same rpm. So the fuel curve will vary from one application to another.
Payton is offline
Old 03-10-2004 | 12:29 PM
All you can say is that at WOT you will burn between 35-40 GPH per motor.
cobra marty is offline
Old 03-10-2004 | 12:38 PM
Stormrider's Avatar
Thanks guys, that is the info I was looking for.
I'll be installing a fuel flow meter that has a 35gph max.
If WOT is 40gph, than I'll be under 35gph more than 95% of the time. Which means the damn thing should be pretty accurate. As opposed to cruising at 3200-3400rpm burning 40gph.
This is what I just got from Merc.
1600rpm 3.6gph
2500rpm 7.3gph
3500rpm 13.4gph
4500rpm 24.3gph
that is as high as they go.
Old 03-10-2004 | 03:12 PM
ragtop409's Avatar
Also depends on the size of prop you turn and the load it creates. I get better milage and mor RPM's with my 23 pitch but the GPS says the 25 pitch is faster at a lower RPM's and uses more gas. go figure Rag's
ragtop409 is offline
Old 03-10-2004 | 03:35 PM
CAP071's Avatar
Just plan on spending lots of $$$ on gas this summer anyway
CAP071 is offline
