TRS drives - parts?
Old 03-15-2004 | 09:52 AM
bford1's Avatar
Question TRS drives - parts?
Well, my star board TRS drive is toast. The marina hasn't taken it apart but it stopped working in forward and it has a bunch of metal shavings in it.
So, what to do now? Do I look for a new (rebuilt??) TRS drive or try to get someone to rebuild mine? The guys at the Marina aren't real confident about it since it's so old. They say they can't get parts, etc. etc.
I heard there was someone in Florida with a bunch of TRS drives and parts. Anyone know of him?
Any suggestions??? (Switching to Bravos isn't an option).
bford1 is offline
Old 03-15-2004 | 09:58 AM
Audiofn's Avatar
Charter Member #232
bford TRS stuff is easy to find still. You should have no problem getting yours fixed or replaced. I will try and get in touch with some guys in this area and see if I can find ya one. I do not remember is this a left or right hand rotation?
Jon
Put your best foot forward!
Audiofn is offline
Old 03-15-2004 | 10:02 AM
bford1's Avatar
Thanks guys. It is the right hand drive and they're counter rotation so I think it is right rotation. Right?
bford1 is offline
Old 03-15-2004 | 10:13 AM
Audiofn's Avatar
Charter Member #232
Look on the end of the prop shaft. See if it has a L or a R stamped on it. If it has a L it is a left. If it has a R or no stamp it is a Right.
Jon
Audiofn is offline
Old 03-15-2004 | 10:17 AM
BajaRunner's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2465028011
heres one on ebay
BajaRunner is offline
Old 03-15-2004 | 10:27 AM
bford1's Avatar
Default Lower Only???
Guys - thanks again for your support. Here's the latest.
I just got off the phone with the marina, South Austin Marine (SAM),. First it is a right hand rotation drive. Secondly they said that the upper seems fine. I either need to rebuild the lower or find just a lower.
Any ideas guys?
bford1 is offline
Old 03-15-2004 | 10:35 AM
check your PM
open87 is offline
Old 03-15-2004 | 10:40 AM
Audiofn's Avatar
Charter Member #232
If it is the lower and it is just the gears you can still get them all and the bearings and they are reasonable. If you get the new ones I understand they they Cryofreeze them now....???? Not sure if that is true or not but just info I have been told. Have some one rebuild the lower. Your uper I would still take apart however just to make sure that parts from the lower did not go up there.
Jon
Audiofn is offline
Old 03-15-2004 | 10:46 AM
The Menace's Avatar
Default Lower unit
My buddy Jim has all the parts, pieces, new and used. I just called him and he has either a right or left lower for $2,500.00
Talk to Jim.
419 732 1777
Ohio
The Menace is offline
Old 03-15-2004 | 11:52 AM
BODYSHOT1's Avatar
Offshore Performance in Ft. Myers Fla has TRS stuff as well....
BODYSHOT1 is offline
