30 spectre
Sonny,
I got mine back in the water after having the engines out. It ran pretty good for the first time out. I saw 108 full of fuel with the 30" hydromotives in not that great of conditions. The engines dynoed at 550 and I put the 2" shortie Imco's.
I did get my but kicked by a brand new 36' Nortech that was out. I guess he is from Hickory?
Sounds like your running good. You need to try my 36 Bravo's. I think you would be impressed. I can't wait to get on the lake. Did you speak with the Nortech guy? Will he be out the lake this summer?
Can't you get those guys at Norman to step up and put on a real Poker Run? Great lake, plent of places to party and plenty of rockin lake sleds in the area=WHAT GIVES???
Later,
Sonny
Later,
Sonny
Those are some good numbers guys.
Sonny, please send me your mailing address, I was cleaning out my file on the 30 and have pictures of the windshield I told you about and the info from the shop in NY.
Also have a pair of race labbed Bravo 34s that don't work on the 36 if anyone is interested. I bought them from Neil Wobbe of Zipp Express and like the 5 blades better.
The best I can tell I'm turning about 5400 RPM with the 30" non labbed hydromotives at 108. I have 1.35 gear ratio. I still need some seat time but as is I would say it will run about 110. The engines dynoed at 550 at 5500 and 570 at 6000.
Sonny, I don't think I can turn your 36's but I would like to try some lab cut 32's if you know of any out there. What gear ratio are you running?
Do you have the large tunnel tab on yours? Do you put it all the way up at wide open?
As far as the Poker Run goes there are some people working on it but I don't think they are putting out the effort in to make it happen this year. The key is to get Queens Landing to host it as they are the only place capable of docking enough boats.
Swede:
I have lab 34 and lab 36 bravos. You will be able to run the 36's. Bravo's don't equiliate to hydro's. I also have a set of 29 Hydromotives I will sell. I expect you will run 111 to 112 with my 36 bravo's. I am running 112 on GPS with 1.35 XR Sportmaster 2" shorter lowers. Don't buy any other props until youtry my props. i will same you alot of headache and money.
What would your opinion be about property just under the 150 bridge in a nice deepwater cove, cleared, has an older dock and has community water. Houses around it are in the 350-700K range, mostlly new construction.
What is you guess for a value? 1 acre.
Sonny
Sonny
I'm game to try those props. Are you going to be down this way anytime? Are you going to the SML Poker Run?
I'm guess you would probably be around 175K to 225k for a nice waterfront lot around 150. If you go up the lake further the prices will drop. I live over on the Denver side of the lake. A 3000 SF waterfront house on about an acres in my subdivision sold for around $450k.
