Bravo 1 top cap oil leak >
Old 03-16-2004 | 12:31 AM
RUSSSR1's Avatar
Default Bravo 1 top cap oil leak
One of my bravo's keeps on blowing the top cap o-ring and leaking oil. I service both drives the same way. What could be the cause of this? I would imagine pressure is being built up in the failing drive. It almost looks as if the o-ring is being pinched on assembly but i am sure that is not the case what could be causing this?
RUSSSR1 is offline
Old 03-16-2004 | 06:45 AM
marinetrans's Avatar
Is it the small o-ring? If it is, don't use any grease or sealer because it will squeeze to the inside. Just clean the groove and set it in dry.Use Perfect Seal on the large o-ring but nothing on the small.
marinetrans is offline
Old 03-16-2004 | 09:27 AM
RUSSSR1's Avatar
It's the large o-ring that is blowing. Not using any sealer on assembly, should I? The cap and case look to be perfect.
RUSSSR1 is offline
Old 03-16-2004 | 10:42 AM
What year drive and what motor is it? Sounds loke the top cap is "walking" around under load. May need to put a billet cap on or use Imco's top cap mod.
Old 03-16-2004 | 10:45 AM
BTW, are you using Merc orings?
Old 03-16-2004 | 10:57 AM
RUSSSR1's Avatar
89' 7.4 330's 300hrs 1.5 B1's 25p mirage 4900rpm max, yes Merc o-rings. Is there any thing that would cause a pressure build up at this point? Is a bravo sealed or is there a vent. I though I remember somthing about problems with the cap on the res. bottle?
Thanks for your input
RUSSSR1 is offline
Old 03-16-2004 | 11:18 AM
Is the drive w/ L.H. prop blowing the o-ring?
Old 03-16-2004 | 12:24 PM
RUSSSR1's Avatar
port side, props turning out. Goto go for a bit will check back later.
Thank you marinetrans
Russ
RUSSSR1 is offline
Old 03-16-2004 | 01:17 PM
Sounds like the top cap is moving around.Makes sense beacuse its the port side w/ L.H. prop. Put on a billet cap w/ stud kit.Billet Marine, Max Worx, Teague all make good billet caps.
Old 03-16-2004 | 08:03 PM
rbtnt's Avatar
ditto on marinetrans
rbtnt is offline
