engine alignment? >
engine alignment?
engine alignment?
Old 03-17-2004 | 12:02 PM
KH0302's Avatar
Default engine alignment?
How can I prove or disprove if my engine is not straight?
I recently had a motor mount stringer replaced. I'm putting Lightnings on the boat and the starboard colector is like 3" from the transom(I can't get the 90* pipe in there), where the port collector is about 6" away. Could the engine have been put back in cocked and that's causing it? If I take a tape to the engine mounts shouldn't they be equal distance from the transom?
Please help...
KH
KH0302 is offline
Old 03-17-2004 | 12:36 PM
sleeker
no one head sits farther forward than the other.actually the whole motor is off set .it all stems from the rods being next to each other on the crank so everthing must be offset just look at the front of the heads port side is farther forward.
Old 03-17-2004 | 10:19 PM
Tinkerer's Avatar
ANY time the drive is removed the engine alignment should be checked.
If the engine is removed the alignment MUST be checked.
Tinkerer is offline
Old 03-17-2004 | 10:38 PM
you use a alignment bar to align the eng it should slide in and out of the coupler easy.
mercmatt22 is offline
jdub
31
09-27-2007 09:03 PM
SmallPP
20
05-07-2007 09:16 PM
boatnt
11
04-16-2006 10:23 PM
35 White Lightning
Fountain
1
04-19-2005 09:18 PM
outlawinil
3
04-21-2004 09:16 AM
