454 mag efi upgrades? >
Old 01-30-2002 | 09:19 PM
checkmate981
Question 454 mag efi upgrades?
I was thinking of moving up to a 454mag efi from a 310efi.Has anybody tryed any upgrades that make good improvements in hp's without supercharging or losing reliability.
Thanks Dave
[ 01-30-2002: Message edited by: checkmate981 ]
Old 01-31-2002 | 12:04 PM
Whiteknuckle's Avatar
Post
I don't get the question? Are you going to try to upgrade your 310 to 454 mag specs or are you going to pull the 310 out and replace it with a 454 mag?
Whiteknuckle is offline
Old 01-31-2002 | 01:48 PM
Revelocity's Avatar
Post
Plenty of people have reliably upgraded the 310HP 7.4 motor up to 385HP (the 454 Mag output) or more but have done so with a carb. setup since reprogramming the ECU is not straight forward. Allegedly the 7.4MPI intake plenum/manifold was poorly designed also.
If you were asking about truely upgrading your 7.4 motor to the 454 MAG components, you'd probably save money and time by just buying a complete 454 Mag since they have little in common other then the block and external bolt-on accessories.
Revelocity is offline
Old 01-31-2002 | 08:46 PM
checkmate981
Post
Sorry,
I was looking to find good upgrades for a 454mag efi 385hp .The 310 is a great engine but did not think it would be a good to build up do to the cast crank,pistons and small rods.
Thanks Dave
Old 02-02-2002 | 01:45 AM
mxz800's Avatar
Post
Revelocity do you have any more info on the intake prob with the 7,4 efi mag 385hp thanx also what bolt ons has any one done to this motor and what outcome good and bad??
mxz800 is offline
JasonSmith
19
07-10-2006 01:49 PM
obsessioncatsass
2
10-11-2005 06:03 AM
aTX427
1
05-29-2004 08:28 AM
blown formula
31
06-10-2003 06:59 PM
dreamer
05-28-2002 10:24 PM
