What Fuel Octane >
What Fuel Octane
What Fuel Octane
Old 03-26-2004 | 10:27 PM
Default What Fuel Octane
I'm running a 500Hp what octane fuel is recommended?
I have heard that these engines like the 87 octane and run their best.
Active Mike is offline
Old 03-26-2004 | 10:35 PM
mcollinstn's Avatar
heard right.
cheaper is better
mcollinstn is offline
Old 03-26-2004 | 10:42 PM
mcollinstn,
What is your experience with this octane? Do you run a 500 hp? I'm wondering if anyone has done test on this engine on a dyno with different fuels?
Old 03-27-2004 | 03:01 PM
mcollinstn's Avatar
AM,
"Additional octane" over and above the design spec of an engine NEVER gives additional performance, if the engine is in a proper state of tune.
The higher the octane rating is, the slower the fuel burn is, and the less btu per pound the fuel has. This is true for all "pump gases".
(We're not talking about race fuel or horsepower cocktails employing oxidizers and/or high volatiles like Nutec for example).
Now if you choose to increase your compression ratio or advance your ignition timing beyond the factory specs then you *may* be able to increase your engine's octane needs beyond the design spec. In that case, you will indeed obtain additional performance because lower octane fuels will be handicapped by the knock sensor on the motor retarding ignition timing away from optimum.
If it makes you happy, though, run 93 in it. Some HP500EFI's will soot up the transom with 93 fuel, but it can always be wiped off...
Old 03-27-2004 | 11:10 PM
If I don't have to run the higher octane that is fine with me specially with the price of fuel this summer.
What octane is recommended the lowest on the pump or stay around the 87?
Old 03-28-2004 | 01:44 PM
mcollinstn's Avatar
HP500 EFI - 500 HP
Specifications
HP: 500
Full Throttle RPM Range: 4800-5200
Compression Ratio: 8.75:1
Fuel System: MPI
Fuel Requirements: 87 Posted Octane (R+M)/2 (92 RON) International
Old 03-28-2004 | 01:45 PM
mcollinstn's Avatar
As long as you are in the good ole U.S. of A., the yellow 87 sticker on the pump will be just fine.
If you travel outside of the US, you will need to know what method they use to figure their octane...
Old 03-28-2004 | 03:10 PM
Stormrider's Avatar
JC Performance Engines
How about the same question for a 454mag 365hp carb'd engine? What octane?
Stormrider is offline
Old 03-28-2004 | 03:28 PM
Tricky919's Avatar
Iv'e heard the same is true for the 496's, is this also right?
Tricky919 is offline
Old 03-28-2004 | 04:38 PM
mcollinstn's Avatar
Guys, it is clearly spelled out in your manual.
And I believe the rule of thumb is that all black Mercruiser motors are setup for 87 octane.
