Horsepower and Torque through Bravo 1 >
Old 02-03-2002 | 04:54 PM
Post Horsepower and Torque through Bravo 1
Does anybody know how much HP and Torque I can put through a Bravo 1. I won't be doing any hole shots and will back off if I catch some air.
Sheikman
sheikman is offline
Old 02-03-2002 | 06:46 PM
puder's Avatar
speel chekk this fokker!
Post
they are rated to 500hp. It seems to depend on the boat. The bigger and heavier the boat the less HP you can put thru it. If you say have a 50' nortech with bravos 500hp is gonna pop em. But you could run 650hp on an 18' runabout and be fine.
Pardon me, while I whip this out!
puder is offline
Old 02-04-2002 | 09:57 AM
MIKEHTMSR24's Avatar
Post
683hp @ 5680 and 676 torq @ 4700
4500 lb cat
1.36 drive
5500 r's
26 pitch 4 blade
320 hrs. on stock drive "knock knock on wood"
MIKEHTMSR24 is offline
Old 02-05-2002 | 09:44 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Post
TRIPLE 500 HP ON A 37 FOOT OUTERLIMITS WEIGHING APPROX 12000 LBS. CATCH SOME AIR IN 3TO5 FOOTERS.KISS THEM GOOD BY!!! TORQUE AGAINST WEGHT AGAINST HORSE POWER. GET A LITTLE TOO MUCH. (BOOM) B.O.A.T. (BREAK OUT ANOTHER THOUSAND)
WILDTHING TAZ is offline
Old 02-06-2002 | 01:39 AM
puder's Avatar
Post
how much does 37 OL with twins weigh??? 12k seems real heavy. The added engine and drive would only be 2000lbs more. that woudl make a standard 37' ol around 10k and i know they can't wieght that much. A 38' kv scarab wieghs 9100 and they are 10 years old???
puder is offline
Old 02-06-2002 | 06:55 AM
Post
Thanks for the input.
Working with a 25' Formula deep vee...
Sounds to me like it might be right on the edge. Boat does weigh 4200 lbs.
Any insight appreciated
Sheikman
sheikman is offline
Old 02-06-2002 | 09:00 PM
B-MAX REPAIR
Post
9100 dry with twin 500's add one 500 3 extension boxes and 225 gal fuel
Old 02-06-2002 | 09:05 PM
B-MAX REPAIR
Post
dont forget air,microwave,tv,corian counter tops,extra battery,frig,tool boxes,an who knows what else.(no fat chicks)
Old 02-06-2002 | 09:39 PM
Post
Where's the BEEF ????
sheikman is offline
Old 02-07-2002 | 01:30 AM
puder's Avatar
Post
yeah that could add up pretty quickly. What kind of speed to you see with her?
shiekman how much power are you planning on putting through the bravo?
puder is offline
