fuel pick-up/check-valve?how to tell >
Old 03-29-2004 | 04:16 PM
Default fuel pick-up/check-valve?how to tell
My '90 fountain 29' has 2 x 454 mags and the pickups are square block with pipe thread barb screwed into the block and no other features. Can I blow backwards to see ? Aeromotive says remove it before my new pump is in.There is no sock on my pick-ups and it's a 113 gal tank.Thanks
cooltoys61 is offline
Old 03-29-2004 | 10:51 PM
mcollinstn's Avatar
yes you can blow.
mcollinstn is offline
Old 03-30-2004 | 12:50 AM
2112's Avatar
Originally posted by mcollinstn
yes you can blow.
Seriously, what IS the best way to test the check valve?
2112 is offline
Old 03-30-2004 | 05:31 AM
I want to know if I have one. Maybe he's serious???
HELP, it's getting warm and the prochargers are waiting.
Old 03-30-2004 | 08:30 AM
mcollinstn's Avatar
yes I'm serious.
Old 03-30-2004 | 10:24 AM
OK,here goes the blow. I've given this boat all my $ and now I'm givin' her H..D
Old 03-30-2004 | 10:56 AM
Just blow on the dang thing, air comes out the other end no check valve. Now suck on it. This ain't rocket science.
BadDog is offline
Old 03-30-2004 | 01:21 PM
Talking
it blows fine,,,,no check
valve. Sucking would only prove I'm a sucker ,,it's supposed to flow that way
Old 03-30-2004 | 02:15 PM
Actually it takes quite a bit to get the check valve to "pop off" if it was there you would know it. Only an experienced date could pull through the check valve.
BadDog is offline
Old 03-30-2004 | 08:38 PM
mcollinstn's Avatar
yeah, something like a half psi is needed to suck thru an anti-siphon. If you CAN do it, it is in your best interest to deny it.
