Compression Readings on 454, 330hp >
Old 03-30-2004 | 06:31 PM
Default Compression Readings on 454, 330hp
Looking at a used boat with twin 454, 330hp version. Broker furnished a recent compression test reading that ranges anywhere from 105 psi to 120 psi. Successive readings were all within 10% of the adjacent cylinder.
What range should a 1989 motor have?
Hour meter reads only 450 hours, but who knows if it's true.
Holy Smokes is offline
Old 03-30-2004 | 06:36 PM
KNOT-RIGHT's Avatar
Another way would be a leakdown test
this is where you can really see what condition it is in.
KNOT-RIGHT is offline
Old 03-30-2004 | 06:38 PM
Danny_Ocean
I just compression-checked my motor (330/454 w/mild cam) and all cylinders read 165 psi. Motor was rebuilt about 5 yrs. ago and has 265 hrs.
D. Ocean
Pompano Beach, FLA
Old 03-30-2004 | 06:45 PM
Biggus's Avatar
My 330's in my old Baja had 155 lbs with 750 hrs on them.
Biggus is offline
Old 03-30-2004 | 06:54 PM
jaybird's Avatar
Not an expert here, but those #'s seem really low. It could be that it hasn't run in a long time, which can influence the #'s. However, I think you should see somewhere approx. between 140-160 lbs.
You said this has twins? Both motors show this reading?
jaybird is offline
Old 03-30-2004 | 07:28 PM
mcollinstn's Avatar
No more than 10% from lowest to highest.
Could be sticking rings from sitting, otherwise it needs some money spent on it.
mcollinstn is offline
Firebird27
3
07-25-2006 10:51 AM
Holy Smokes
30
07-18-2005 11:26 AM
HOTTZU98
0
06-07-2005 10:29 PM
FunHome
3
06-15-2004 01:25 PM
Fightclub
28
04-21-2004 03:23 PM
