boat Launch Backup lights tahoe/yukon
here is my first Tahoe Mod remove cover off Z71 roof rack, drill Hole for new light.. Make sure you have a light
that will fit this app.
now there is some lights
, I put them on a switch
but with a relay you could put them on your backup light
circuit, Dont wire direct to the backup light, Too much current
, I put them on a switchbut with a relay you could put them on your backup light
put a couple 50 watt halogens and it lights up the whole ramp
I would'nt go much higher because the housing is plastic and might melt with 100s
I do the same on my trucks, I was wondering why GM didnt do that as a factory option.
Looks great.
I wire mine though a relay on a switch and a seperate relay through the back up light trailer harness to turn on by reverse lights and by a seperate switch.
Looks great.
Looks great.
Looks great.
wired relay through hot acessory juice so it cannot
be accidently left on and drain battery
If you have any question as to how to wire have a friend
that fully understands auto electric help you
