which cam?
525ci blower motor with dart heads. CMI elbow top exhaust. Final compression ratio still to be determined but was thinking about 8 to 1. Ran a crane 139651 on a 540ci but was considering stepping up to 139661 or ? Would like to stay with a hydraulic roller. What you think?
This is the cam that I an running in my 454 with a 177 blower. It was designed by Jason Saris At performance Marine in Lake George NY. In a 525SC that they had on the dyno it ran 609hp. I don't know what else they did to the motor internally. It was custom ground by Iskederian Racing Cams.
...............intake / exhaust
duration..........275 / 284
duration @.050....228 / 238
valve lift........552 / 578
lobe center.......112 / 112
overlap...........55.5
calculated with a 1.7 rocker
I can give you more info if you like.
Paul
[ 02-05-2002: Message edited by: HOT BOAT ]
Paul
If it aint broke .... I can break it....
