NASCAR on IMAX
I'll tell you what, If you can't boat because of the weather you need to see this. It has everything you need; speed, loud engines, and it is all right in your face. You want to reach out and touch it and when the tire comes at you after a wreck you will duck, I guarantee it
My hair was on end the entire time, I had goose bumps the entire time. I am right across the street from a theater where I am staying in Ohio and could not believe my luck. It is in 3 D and will make you want to yell out like you are at a real race. It is absolutely the best film you will ever see. There are shots of Richard Petty in his first races and the closups are so real you can see his face clearly, they must have used old footage and converted it. There are closups of an engine being torn down and the push rods are as big as your thumb. I wanted to get in my truck and race when I got out.
I thought it had been out for a while, I guess I got lucky, there was no one in the theater where I was, I bet in Grand Rapids it will be packed. I plan on seeing it again. There is a shot of the front suspension and I swear you could touch it. It is as good as a good roller coaster.
