Water reversion with Crane 741 cams >
Old 04-01-2004 | 08:50 AM
Monty's Avatar
Default Water reversion with Crane 741 cams
This was posted on another forum, but there were only a couple of responses. I know alot of people use the 541 here, has anyone had any water reversion problems with this cam, especially on a 540+ engine?
I was told by Stainless Marine that I would need the longer risers with the 741 cam because they don't recommend using their standard length risers with cams that have more than 230* duration at 0.050". Between the new 540's, upholstery, swim platform, and all the rerigging I've done to the boat, I sure would prefer not to have to spend another $2000 on new risers.
Would it be a representative test to run the engines on the hose to see if water reversion is a problem, prior to actually running the boat in the water for an extended period of time?
Monty is offline
Old 04-01-2004 | 09:19 AM
IF THIS CAM IS IN AN ENGINE LARGER THAN 540 CU INCH AND IS PULLING WATER YOU ARE DEFINITELY GOING TO NEED A TALLER RISER ONE THING YOU MIGHT ASK JERRY AT STAINLESS IF HE COULD WELD AND RELOCATE THE WATER OUTLET TO THE OUTSIDE OF THE TRANSOM OR IN OTHER WORDS MAKE THE EXHAUST DRY THIS WILL WORK AND SAVE YOU MONEY BOTH . ON MARINE ENGINES LIKE THIS I KNOW EVERYONE HAS DIFFERENT OPINIONS BUT I ALWAYS RUN 114 LOBE SEPARATION AND IT HELPS IN CONTROLLING THE REVERSION PROBLEM. IF YOU HAVE ANY QUESTIONS OR YOU NEED TECH HELP CALL US AT 1-305-884-5368 LAZ MESA WWW.MESABALANCING.COM
MESABALANCING is offline
Old 04-01-2004 | 09:33 AM
magnum27's Avatar
YEA YEA GO DRY!!! There is nothing that sounds sweeter to a Marine Gear Head than dry pipes.
magnum27 is offline
Old 04-01-2004 | 09:45 AM
dyno's Avatar
Charter Member #655
Around here the cops like them too!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 04-01-2004 | 10:56 AM
Official OSO boat whore
I was told the same thing with my engine. I went with a Lightning header (because of cost) but I had them dump the water over (dry tail). I then had a 3/8" bung welded into the tail that allows me to electrically control the flow of water. If I have a long idle, I can turn the water off and prevent reversion. To keep the temps down, I like to cycle the water on for 10-15 seconds every couple of minutes. I have a second pressure sensitive valve that then dumps water into the tail when the block pressure starts to rise. I have its set so it starts to open just above idle. Set like this it will mist a tiny amount of water into the tail pipe. Not much, just enough to keep the paint on the tail pipes. Noise wise, the boat is definetly over the limit. I'm pretty sure that the Teague muffs will get me real close to the limit and that if I turn up the pressure valve and turn on the idle water that I'd pass. I do know that if I turn up the pressure valve too high at idle, that I can hear the engine tone change. At this point I'm pretty sure that I'm seeing reversion.
Cord is offline
Old 04-01-2004 | 05:07 PM
Cignificant's Avatar
I run the roller version of the 741s on 502s with CMI elbow-tops & blowers and have never had a reversion problem.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 04-01-2004 | 05:50 PM
blue thunder's Avatar
Default Re: Water reversion with Crane 741 cams
The answer is yes, but you will need to pull a riser promptly after shutdown to check for dampness in the exhaust chamber.
BT
blue thunder is offline
whoya
7
05-06-2008 11:01 PM
teaguecustommarine
New Products and Member Discounts
5
02-22-2008 06:11 PM
Croozin2
18
09-27-2007 07:31 AM
Outdrive1
9
03-10-2006 08:12 PM
StrikinLightnin
21
11-04-2004 04:28 PM
