Fuel pump cam lobe excessive ware???
Last season while tearing down one of my motors I noticed an excessive amount of wear on the cam lobe that runs the mechanical fuel pump. The lobe was worn off close to a third of its original size. I am in the process of having the other motor freshened up and this cam is incredibly worn on the fuel pump lobe as well.
I know many well known engine builders use the 130 gph pumps on their blower motors but is this the result of the heavy spring pressure from the large volume 130 gph pump?
I hate the thought of ruining a motor because of the cam material shedding from running a mechanical fuel pump!
These motors had less than 150 hrs
What do you think?
Kurt
What do you think?
Kurt
Kurt,
The lobe wear is not uncommon. Happens to everything from vanilla 330's and up. Some wear much faster than others.
Is one of the first things I look at when somebody tells me that their BBC just started getting really hard to start when it has been sitting a couple of weeks.
This just blows me away! I've been playing with performance boats for over 20 yrs and seem to learn someting new everyday
Wouldn't you think you would have a low fuel pressure problem with the lobe wearing as much as I have just experienced but that was not the case. Fuel pressure was 8.5 lbs idle and 5.5 under boost
the lobe was missing two thirds!
Can the lobe wear be eliminated by going to a better pushrod?
Kurt
the lobe was missing two thirds!Can the lobe wear be eliminated by going to a better pushrod?
Kurt
Thanks for the info guys!
The Comp Cams website mentions the need to run a bronze tip pushrod when running a steel roller cam or damage will result!
Comp Cams #4607 bronze tip pushrod.
Kurt
Kurt
