454 mag
Old 04-04-2004 | 01:12 PM
chubbytug
Default 454 mag
Can anyone here tell me what the differences are between a stock 330 hp 454 and the 365 hp 454 mag?
Old 04-04-2004 | 01:22 PM
38KV's Avatar
The 330 have two bolt mains, cast crank and pistons, small port heads and low cast iron intake.
The 365 have four bolt mains, 7/16" rods, forged crank and pistons, large port heads, hi-rise aluminium intake, different cam and CR.
38KV is offline
Old 04-04-2004 | 03:52 PM
Payton's Avatar
Charter Member #927
Some call the 454 Mag 385hp. Did they dump it up when they went fuel injected?
Payton is offline
Old 04-04-2004 | 09:54 PM
mcollinstn's Avatar
The 365 was 1988ish thru 1991 or so.
Externally, the 365 has an aluminum high rise GM intake. It is painted black, but you can put a magnet to it and tell easily enough. That'll be your EASIEST tip off.
mcollinstn is offline
mg503
Baja
14
04-03-2013 04:50 PM
cliff3466
1
03-09-2008 08:10 AM
wet_rat
09-26-2007 12:01 AM
thanks_don
11-19-2006 08:24 PM
Cmoney
3
08-02-2004 11:15 PM
