Sportmaster lowers
Old 04-10-2004 | 10:05 AM
Default Sportmaster lowers
I ordered a new 35 Nordic w/525's XR w/sportmaster lowers and have been told that the sportmasters only work on tunnels. Reasoning, the sportmaster creates stern lift that hurts Vee hulls.
Any help would be appreciated.
39 Unlimited is offline
Old 04-10-2004 | 11:29 AM
Dusty Times's Avatar
Gary,
You might want to contact Randy Hanson that has Pet This. The 38 Hustler with 575's and Sportmasters. I think from what I have heard that he couldn't be happier but I'm not sure.
Dusty Times is offline
Old 04-10-2004 | 07:50 PM
RJ1340's Avatar
Your props have more to do with bow/stern lift than your drives. If you find you need more bow lift, you can send your props to Throttle Up or Houston Props to have them cupped differently. I think with that setup you should try a stainless steel 5-blade.
RJ1340 is offline
Old 04-10-2004 | 09:14 PM
LapseofReason's Avatar
One of the main reasons for the Sportmaster lower is the better skeg. If you are running a high Xdim. you want the sport masters for better control.
LapseofReason is offline
Old 04-11-2004 | 04:55 AM
Hot Duck's Avatar
We are running the Sportmaster XRs with the ITS setup on a Gladiator and they have been great. From what we have seen, there are no problems running them on a vee hull.
Hot Duck is offline
Old 04-11-2004 | 04:58 AM
Hot Duck's Avatar
Another angle.
Hot Duck is offline
Old 04-11-2004 | 07:35 AM
Hot Duck.......do yo have any pics of the side and front.............your idea in the rear to keep the cover on is great. I had the same thing in mind. Especially to keep the cover from slapping the gel
Thanx
JB
enticer is offline
Old 04-11-2004 | 08:45 AM
LPBoater's Avatar
Wink
Gary - you're getting bad info. they will work fine at 35 mph -
LPBoater is offline
Old 04-11-2004 | 09:10 AM
Waterfoul's Avatar
Gone Fishin'
What's the difference between the Sportmaster and a standard bravo??
Waterfoul is offline
Old 04-11-2004 | 04:04 PM
Thanx for the info. Nordic advised against the Sportmasters because of stern lift. Not sure why had nose cones on my 2000 35 and it ran great.
Looks like Sportmaters it is.
LP, 35 maybe slightly optimistic.
