502 mpi/bravo xr OR 496ho with bravo x? >
View Poll Results: What power would you take for same price?
Used 502 MPI with new bravo XR
9
45.00%
new 496HO with new bravo X
11
55.00%
Voters: 20. You may not vote on this poll
Old 04-13-2004 | 10:53 AM
mirageman
Question 502 mpi/bravo xr OR 496ho with bravo x?
Here is a question or actually a poll for you folks. Say for example you were to purchase a new single engine V-boat i.e. Superboat 30y2k or Pantera 28 and planned to eventually supercharge whatever motor you were to get with it, and initially only had enough money for either the 496HO with standard bravo drive, or a slightly used (Less than 15 hours) 502mpi and a new bravo XR which would you take?
Old 04-13-2004 | 11:01 AM
The 496,it has 2 more head bolts per side for better sealing
Dixie Doug is offline
Old 04-13-2004 | 02:33 PM
mirageman
So far it is really looking like the 496!!!!!
Old 04-13-2004 | 03:01 PM
cstraub69@comcast
502, you have far more choices in cylinder heads and induction systems for the older GM Big Block series. Aftermarket parts are and will be much cheaper for years to come.
Chris
Old 04-13-2004 | 05:31 PM
ccscarab
Default 502vs496
502- forged internals
496 Cast internals
Buy the 502 add iconel valves, new head gaskets, external steering, and whipple.
Old 04-14-2004 | 08:33 PM
Fuelish Pleasures
The stock 496 is not the best engine to try and supercharge. The stock compression is higher than the 502, which would mean less boost available to run, and the stock pistons are probably the weak link for this application. Now if you are willing to modify the 496 and change out the weak links, it may turn out to be the best choice. There are several aftermarket parts now or soon to be available that may make this engine the better of the two. Time will tell.
nsformula
Drives and Lower Units
5
11-16-2008 04:36 PM
naturalhigh
Prop Talk
2
07-31-2006 08:18 AM
wwwTOPDJcom
2
12-15-2003 06:45 PM
Love Machine
2
09-09-2003 05:03 PM
CONDOR24
0
04-15-2002 05:13 PM
