Need Help With Prop Size >
Old 04-13-2004 | 11:40 AM
Default Need Help With Prop Size
30FT LONG V BOTTOM TRIPLE STEP NINE INCH NOTCH 4500LBS WITH 675HP AND A SPEEDMASTER #4, RATIO 1.65 X WILL BE EVEN WITH THE BOTTOM.WHAT PROP PITCH WILL BE A GOOD PLACE TO START.3 BLADE OR 4 MY MAGIC 8 BALL KEEPS SAYING TRY ME AGAIN LATER.
z.zuperboat is offline
Old 04-14-2004 | 06:13 AM
throttleup's Avatar
z.zuperboat,
I need to know what your WOT rpm will be. If you have dyno sheets on the motors that's the best way to determine that.
With the prop shaft height you mentioned I would go with a 4 or 5 blade prop.
Who makes the hull? Sounds like a SVL boat?
Matt
throttleup is offline
Old 04-15-2004 | 06:52 AM
WOT RPM I WANT TO BE AROUND 6000.THE MOTORS NOT TOGETHER YET THE CAM POWER BAND IS FROM 3200-6800.BUT YES THE DYNO WOULD BE HELP FULL.HP ESTIMATE NOW IS 645-665.BUT THAT MEANS NOTHING WE NEED TORQUE SPECKS. THE HULL IS A SUPERBOAT AND WHEN ORIGINALLY RIGGED WITH 20 GALLONS OF FUEL IT WEIGHTED IN AT 4200.THANKS MATT FOR YOUR TIME.
Old 04-15-2004 | 12:52 PM
throttleup's Avatar
z.zuperboat,
You should need a 28-30 depending on how the boat performs and what kind of water conditions you plan to run in.
I used 9% as a slip number in these calculations. You should be pretty close to that.
This boat sounds similar to an old A boat.
Matt
Old 04-16-2004 | 07:28 PM
I'd email Darin at [email protected] Send in all your specs an I bet he'd give you the answer your looking for .....................
88 MACH 1 is offline
deanpp
Prop Talk
8
05-10-2007 09:49 AM
Mikey Likes It
Prop Talk
2
04-03-2006 09:25 PM
24Baja
0
06-17-2005 01:29 PM
Dave1972
0
07-08-2002 10:37 AM
mleslie951
Apache
1
05-05-2002 09:31 AM
